Dear Experts,
I am reaching out to seek assistance with a compilation error I am encountering while working on a project with Intel Quartus Prime 23.3.
I have downloaded the project files(qar) from the following link:
The error message I am facing during the compilation process is as follows:
Error ID:22501
ptile_4x4/dni/sandboxes/35236_0/sld/sld_sysconfiles/periph_clk.sopcinfo' database could not be copied to
ptile_4x4/qdb/_compiler/ghrd_agfb014r24b2e2v/root_partition/23.3.0/partitioned/1/sld_sysconfiles/periph_clk.sopcinfo.
I would greatly appreciate your guidance and support in resolving this issue.
Thanks & Regards
Raju Satrasala
For Linux bitstream error, please follow the below steps to run the pre-built binaries for Agilex® 7 FPGA F-Series PCIe Root Port Reference Design --> https://www.rocketboards.org/foswiki/Documentation/AgilexPcieRootPort.?elq_cid=11325872_ts1698719844198&erpm_id=12677771_ts1698719844198
1. Download the sd card image.
https://www.rocketboards.org/foswiki/pub/Documentation/AgilexPcieRootPort/sdimage.tar.gz
2. Copy the images to Sd card using linux dd commands or windows-win32 Disk Imager utility.
3. Open the Sd card files in PC and replace the existing kernel.itb file with this https://www.rocketboards.org/foswiki/pub/Documentation/AgilexPcieRootPort/kernel.itb
4. Insert the SD card in board, change the switches as below-
SW1: ON-OFF-OFF-ON
SW2: all OFF
SW3: OFF-OFF-ON-ON-ON-ON
SW4: OFF-OFF-OFF-ON
5. Open the programmer, autodetect and select the AGILEX_HPS device in the JTAG scan chain.
6. Select the AGB014R24B device from the JTAG scan chain and click on Change File.
7. Program the .sof from https://www.rocketboards.org/foswiki/pub/Documentation/AgilexPcieRootPort/ROOTPORT_Release_1_0_ptile_4x4_hps.sof
8. Now you will see the bootloader starts but initially first time it will give the error and will stop at uboot.
9. Enter bootm at uboot.
10. Now the linux will start booting on board and enter with root login and password.
11. Enter the “lspci -v” to see the PCIe.
Tiwari
Hi Intel Embedded team,
Appreciate if the team can help to look at this.
Refer previous case at https://community.intel.com/t5/FPGA-SoC-And-CPLD-Boards-And/Agilex-Error-Sending-Bitstream/m-p/1535351#M26097
Customer issue on below during Linux boot-up Process, File checked, no corruption
“Error sending bitstream!”
“FPGA image is corrupted or invalid.”
“SCRIPT FAILED: continuing…”
" Unable to read file / "
Wincent_Intel
Hi Raju,
Please help me to understand nature of the raised issue as I see two different issue on same forum thread.
Are you facing issue which the Quartus/PD compilation issue or the linux boot up issue.
Tiwari
Hi @Jeet14 ,
Thanks for your response.
We are facing issue with Quartus Compilation of PCIe Rocket Board Example Design Project as well as Linux Boot Up.
Thanks & Regards
Raju Satrasala
As discussed on call, can you please use the same tool version 23.2 mentioned on below link for Design PCIe RootPort Quartus Compilation.
For linux bitstream errors, I will try at my end with pre-built binaries/images and will update you soon.
Tiwari
SW1: ON-OFF-OFF-ON
SW2: all OFF
SW4: OFF-OFF-OFF-ON
Tiwari
