告知
17268 ディスカッション
Compilation Fails due to Qsys error
名誉コントリビューター II
1,222件の閲覧回数
Hello everyone.
I am working on a big OpenCL project. I have installed the suite, and I have been able to compile some design examples that were using single work-items kernels, so I thought that everything was working properly.
Hence I started writing my own project, modifying upon an existing structure, and including kernels with multiple work-items. But now, when I try to compile for any board, I get the following error, after some compilation steps:
Error - failed to launch '"c/altera/15.0/quartus/bin64\jre64\bin\java.exe" -Xmx1500M -XX:+UseSerialGC "com.altera.qsys.tcl.QsysScript" "--script=kernel_system.tcl" "-Xmx512M" "-XX:+UseSerialGC" '.
If I try modifying the kernels to make them single work-items kernels, then the compilation proceeds and no failure occurs.
Out of curiosity, I downloaded some multiple work-items example designs from Altera website, and I obtained the same error.
Any clue on what the problem might be? I imagine there is some installation issue but I can't figure it out.
Thanks for your help!
0 件の賞賛
0 返答(返信)
返信
