17253 Discussions
Conduits - Verilog and Quartus block sch editor
Hello all,
I believe that its possible to group a couple of dis-similar buses, and associated control lines into a single conduit. So rather than having to drag two buses and two control lines around a schematic it may be possible to use a single entity.
I will be must grateful if someone can point me at a verilog and sch example of this if indeed it is possible.
Mark
In block schematic you can merge buses by separating bus names with commas in the bus name.
For example, if you have 3 buses busA[3:0], busB[7:0], busC[1:0], drag connection from each of them to a 'backbone' bus going around the schematic.
Then rename it as : busA[3:0],busB[7:0],busC[1:0]
Similarly in Verilog oyu can use the {busA[3:0],busB[7:0],busC[1:0]} syntax to create a single bus
just what I needed, many thanks.
