公告
17268 讨论
Config-via-Protocol (CvP) on Cyclone V
名誉分销商 II
1,355 次查看
According to ug_cvp.pdf (http://www.altera.com/literature/ug/ug_cvp.pdf) Cyclone V supports CvP, but if I follow the tutorial targetting the Cyclone V GT devkit, the CvP device options are greyed out:
http://i.imgur.com/UP0ay03.png
If I ignore that and continue, when it's time to split the programming file into periphery and core, I hit a brick wall:
http://i.imgur.com/SfQK7uP.png
As a sanity-check, I tried with the Stratix device mentioned in the tutorial, and that works fine:
http://i.imgur.com/mp3hTE1.png
My Quartus version is 13.1.4 (build 182). Am I doing something wrong? Or is CvP just not supported on Cyclone V after all?
Chris
0 项奖励
1 回复
名誉分销商 II
621 次查看
Hi prophet36,
I have exactly the same problem, do you solved it ?
I tryied also with version 14.0 of quartus but i can't upgrade the component alt_xcvr_reconfig.
I tryied on Linux and Windows but failed.
If someone has any clue ?
0 项奖励
回复
