17268 Discussions
Error using Simulaton waveform editor
Hi, simulating my code I have this problem:
# ** Error: Waveform.vwf.vt(59): near ",": syntax error, unexpected ','
# ** Error: c:/altera/14.0/modelsim_ase/win32aloem/vlog failed.
# Executing ONERROR command at macro ./decoder.do line 4
Error.
In some codes I use (as simple shift registers, sipo, piso) i had similar problems. In others no!
I specify that the codes compilation are always ok.
The code I use is in this case:
--decoder 4 in 16 output
library IEEE;
use ieee.std_logic_1164.all;
entity decoder is
port (
in_sel : in std_logic_vector (3 downto 0);
output : out std_logic_vector (7 downto 0)
end decoder;
architecture decoder_arc of decoder is
begin
A: process (in_sel)
begin
case in_sel is
when "0000" => output <= "00000001";
when "0001" => output <= "00000001";
when "0010" => output <= "00000010";
when "0011" => output <= "00000010";
when "0100" => output <= "00000100";
when "0101" => output <= "00000100";
when "0110" => output <= "00001000";
when "0111" => output <= "00001000";
when "1000" => output <= "00010000";
when "1001" => output <= "00010000";
when "1010" => output <= "00100000";
when "1011" => output <= "00100000";
when "1100" => output <= "01000000";
when "1101" => output <= "01000000";
when "1110" => output <= "10000000";
when "1111" => output <= "10000000";
end case;
end process A;
end architecture;
I attach the project.
Thanks for your attention!
This is not the code the error relates to - the error is some incorrect syntax in the waveform file.
Btw, your VHDL is syntaxtically wrong as you have not included an others choice in the case statement.
