According to ug_cvp.pdf (http://www.altera.com/literature/ug/ug_cvp.pdf) Cyclone V supports CvP, but if I follow the tutorial targetting the Cyclone V GT devkit, the CvP device options are greyed out:
http://i.imgur.com/UP0ay03.png If I ignore that and continue, when it's time to split the programming file into periphery and core, I hit a brick wall: http://i.imgur.com/SfQK7uP.png As a sanity-check, I tried with the Stratix device mentioned in the tutorial, and that works fine: http://i.imgur.com/mp3hTE1.png My Quartus version is 13.1.4 (build 182). Am I doing something wrong? Or is CvP just not supported on Cyclone V after all? ChrisLink Copied
Hi prophet36,
I have exactly the same problem, do you solved it ? I tryied also with version 14.0 of quartus but i can't upgrade the component alt_xcvr_reconfig. I tryied on Linux and Windows but failed. If someone has any clue ?
