17268 Discussions
Confusing cells number while compiling
When I compile below code in Quartus 8.1 Web Edition for synthesis on Altera DE2-70, I get 32 logic elements in Compilation Report.
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity adder is generic ( reg_size : natural := 32 ); port ( a : in std_logic_vector (reg_size - 1 downto 0); b : in std_logic_vector (reg_size - 1 downto 0); s : out std_logic_vector (reg_size - 1 downto 0) ); end adder; architecture rtl of adder is begin s <= a + b; end rtl;
But when compile much bigger code, I get 0 logic elements.
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity scaler is generic ( reg_size : natural := 32 -- input/output register width ); port ( a : in std_logic_vector (reg_size - 1 downto 0); s : out std_logic_vector (reg_size - 1 downto 0) ); end scaler; architecture rtl of scaler is type reg_array is array(natural range<>) of std_logic_vector(reg_size - 1 downto 0); signal adder_in : reg_array(0 to 14); signal adder_out : reg_array(0 to 15); begin adder_in(0)(reg_size - 2 downto 0) <= a(reg_size - 1 downto 1); adder_in(0)(reg_size - 1) <= a(reg_size - 1); adder_out(0) <= a + adder_in(0); adder_in(1)(reg_size - 3 downto 0) <= adder_out(0)(reg_size - 1 downto 2); gen_adder_in_1 : for i in reg_size - 2 to reg_size - 1 generate adder_in(1)(i) <= adder_out(0)(reg_size - 1); end generate; adder_in(1) <= a + adder_out(1); adder_in(2)(reg_size - 2 downto 0) <= adder_out(1)(reg_size - 1 downto 1); adder_in(2)(reg_size - 1) <= adder_out(1)(reg_size - 1); adder_in(2) <= a + adder_out(2); adder_in(3)(reg_size - 3 downto 0) <= adder_out(2)(reg_size - 1 downto 2); gen_adder_in_3 : for i in reg_size - 2 to reg_size - 1 generate adder_in(3)(i) <= adder_out(2)(reg_size - 1); end generate; adder_in(3) <= a + adder_out(3); adder_in(4)(reg_size - 2 downto 0) <= adder_out(3)(reg_size - 1 downto 1); adder_in(4)(reg_size - 1) <= adder_out(3)(reg_size - 1); adder_in(4) <= a + adder_out(4); adder_in(5)(reg_size - 2 downto 0) <= adder_out(4)(reg_size - 1 downto 1); adder_in(5)(reg_size - 1) <= adder_out(4)(reg_size - 1); adder_in(5) <= a + adder_out(5); adder_in(6)(reg_size - 4 downto 0) <= adder_out(5)(reg_size - 1 downto 3); gen_adder_in_6 : for i in reg_size - 3 to reg_size - 1 generate adder_in(6)(i) <= adder_out(5)(reg_size - 1); end generate; adder_in(6) <= a + adder_out(6); adder_in(7)(reg_size - 3 downto 0) <= adder_out(6)(reg_size - 1 downto 2); gen_adder_in_7 : for i in reg_size - 2 to reg_size - 1 generate adder_in(7)(i) <= adder_out(6)(reg_size - 1); end generate; adder_in(7) <= a + adder_out(7); adder_in(8)(reg_size - 2 downto 0) <= adder_out(7)(reg_size - 1 downto 1); adder_in(8)(reg_size - 1) <= adder_out(7)(reg_size - 1); adder_in(8) <= a + adder_out(8); adder_in(9)(reg_size - 2 downto 0) <= adder_out(8)(reg_size - 1 downto 1); adder_in(9)(reg_size - 1) <= adder_out(8)(reg_size - 1); adder_in(9) <= a + adder_out(9); adder_in(10)(reg_size - 3 downto 0) <= adder_out(9)(reg_size - 1 downto 2); gen_adder_in_10 : for i in reg_size - 2 to reg_size - 1 generate adder_in(10)(i) <= adder_out(9)(reg_size - 1); end generate; adder_in(10) <= a + adder_out(10); adder_in(11)(reg_size - 2 downto 0) <= adder_out(10)(reg_size - 1 downto 1); adder_in(11)(reg_size - 1) <= adder_out(10)(reg_size - 1); adder_in(11) <= a + adder_out(11); adder_in(12)(reg_size - 3 downto 0) <= adder_out(11)(reg_size - 1 downto 2); gen_adder_in_12 : for i in reg_size - 2 to reg_size - 1 generate adder_in(12)(i) <= adder_out(11)(reg_size - 1); end generate; adder_in(12) <= a + adder_out(12); adder_in(13)(reg_size - 2 downto 0) <= adder_out(12)(reg_size - 1 downto 1); adder_in(13)(reg_size - 1) <= adder_out(12)(reg_size - 1); adder_in(13) <= a + adder_out(13); adder_in(14)(reg_size - 4 downto 0) <= adder_out(13)(reg_size - 1 downto 3); gen_adder_in_14 : for i in reg_size - 3 to reg_size - 1 generate adder_in(14)(i) <= adder_out(13)(reg_size - 1); end generate; adder_in(14) <= a + adder_out(14); adder_out(15)(reg_size - 2 downto 0) <= adder_out(14)(reg_size - 1 downto 1); adder_out(15)(reg_size - 1) <= adder_out(14)(reg_size - 1); incrementor : entity work.incrementor generic map ( reg_size => reg_size ) port map ( adder_out(15), adder_out(14)(0), s ); end rtl;
What is it caused by?
What resources are used in the second example?
Edit: Problem solved. There was a mistake in the code.
