When I compile below code in Quartus 8.1 Web Edition for synthesis on Altera DE2-70, I get 32 logic elements in Compilation Report.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity adder is
generic (
reg_size : natural := 32
port (
a : in std_logic_vector (reg_size - 1 downto 0);
b : in std_logic_vector (reg_size - 1 downto 0);
s : out std_logic_vector (reg_size - 1 downto 0)
end adder;
architecture rtl of adder is
begin
s <= a + b;
end rtl;
But when compile much bigger code, I get 0 logic elements.
library ieee;
entity scaler is
generic (
reg_size : natural := 32 -- input/output register width
port (
end scaler;
architecture rtl of scaler is
type reg_array is array(natural range<>) of std_logic_vector(reg_size - 1 downto 0);
signal adder_in : reg_array(0 to 14);
signal adder_out : reg_array(0 to 15);
begin
adder_in(0)(reg_size - 2 downto 0) <= a(reg_size - 1 downto 1);
adder_in(0)(reg_size - 1) <= a(reg_size - 1);
adder_out(0) <= a + adder_in(0);
adder_in(1)(reg_size - 3 downto 0) <= adder_out(0)(reg_size - 1 downto 2);
gen_adder_in_1 : for i in reg_size - 2 to reg_size - 1
generate
adder_in(1)(i) <= adder_out(0)(reg_size - 1);
end generate;
adder_in(1) <= a + adder_out(1);
adder_in(2)(reg_size - 2 downto 0) <= adder_out(1)(reg_size - 1 downto 1);
adder_in(2)(reg_size - 1) <= adder_out(1)(reg_size - 1);
adder_in(2) <= a + adder_out(2);
adder_in(3)(reg_size - 3 downto 0) <= adder_out(2)(reg_size - 1 downto 2);
gen_adder_in_3 : for i in reg_size - 2 to reg_size - 1
generate
adder_in(3)(i) <= adder_out(2)(reg_size - 1);
end generate;
adder_in(3) <= a + adder_out(3);
adder_in(4)(reg_size - 2 downto 0) <= adder_out(3)(reg_size - 1 downto 1);
adder_in(4)(reg_size - 1) <= adder_out(3)(reg_size - 1);
adder_in(4) <= a + adder_out(4);
adder_in(5)(reg_size - 2 downto 0) <= adder_out(4)(reg_size - 1 downto 1);
adder_in(5)(reg_size - 1) <= adder_out(4)(reg_size - 1);
adder_in(5) <= a + adder_out(5);
adder_in(6)(reg_size - 4 downto 0) <= adder_out(5)(reg_size - 1 downto 3);
gen_adder_in_6 : for i in reg_size - 3 to reg_size - 1
generate
adder_in(6)(i) <= adder_out(5)(reg_size - 1);
end generate;
adder_in(6) <= a + adder_out(6);
adder_in(7)(reg_size - 3 downto 0) <= adder_out(6)(reg_size - 1 downto 2);
gen_adder_in_7 : for i in reg_size - 2 to reg_size - 1
generate
adder_in(7)(i) <= adder_out(6)(reg_size - 1);
end generate;
adder_in(7) <= a + adder_out(7);
adder_in(8)(reg_size - 2 downto 0) <= adder_out(7)(reg_size - 1 downto 1);
adder_in(8)(reg_size - 1) <= adder_out(7)(reg_size - 1);
adder_in(8) <= a + adder_out(8);
adder_in(9)(reg_size - 2 downto 0) <= adder_out(8)(reg_size - 1 downto 1);
adder_in(9)(reg_size - 1) <= adder_out(8)(reg_size - 1);
adder_in(9) <= a + adder_out(9);
adder_in(10)(reg_size - 3 downto 0) <= adder_out(9)(reg_size - 1 downto 2);
gen_adder_in_10 : for i in reg_size - 2 to reg_size - 1
generate
adder_in(10)(i) <= adder_out(9)(reg_size - 1);
end generate;
adder_in(10) <= a + adder_out(10);
adder_in(11)(reg_size - 2 downto 0) <= adder_out(10)(reg_size - 1 downto 1);
adder_in(11)(reg_size - 1) <= adder_out(10)(reg_size - 1);
adder_in(11) <= a + adder_out(11);
adder_in(12)(reg_size - 3 downto 0) <= adder_out(11)(reg_size - 1 downto 2);
gen_adder_in_12 : for i in reg_size - 2 to reg_size - 1
generate
adder_in(12)(i) <= adder_out(11)(reg_size - 1);
end generate;
adder_in(12) <= a + adder_out(12);
adder_in(13)(reg_size - 2 downto 0) <= adder_out(12)(reg_size - 1 downto 1);
adder_in(13)(reg_size - 1) <= adder_out(12)(reg_size - 1);
adder_in(13) <= a + adder_out(13);
adder_in(14)(reg_size - 4 downto 0) <= adder_out(13)(reg_size - 1 downto 3);
gen_adder_in_14 : for i in reg_size - 3 to reg_size - 1
generate
adder_in(14)(i) <= adder_out(13)(reg_size - 1);
end generate;
adder_in(14) <= a + adder_out(14);
adder_out(15)(reg_size - 2 downto 0) <= adder_out(14)(reg_size - 1 downto 1);
adder_out(15)(reg_size - 1) <= adder_out(14)(reg_size - 1);
incrementor : entity work.incrementor
generic map (
reg_size => reg_size
port map (
adder_out(15),
adder_out(14)(0),
s
end rtl;
What is it caused by? What resources are used in the second example? Edit: Problem solved. There was a mistake in the code.
