17252 Discussions
Connectivity Checks report folder -> where is it?
Hi All,
While compiling my design, I'm receiving the following:
--- Quote Start ---
Warning (12241): 2 hierarchies have connectivity warnings - see the Connectivity Checks report folder.
--- Quote End ---
Where is the Connectivity Checks report folder? For some reason I cannot find it under the ./project/quartus/ folder.
Thank you!
you can find it in Quartus program, Compilation Report tab -> Analysis & Synthesis -> Conectivity Checks
Is there a possibility to see these reports in the TXT format? What's a physical location (folder/directory) of the reports in the Quartus-II environment?
It should be in the .map.rpt.
Where do you see that warning? If a text file, it should also be the .map.rpt. If in the GUI, clicking in the GUI might be easier. (I find the GUI easier to manage for many of the reports, although two connectivity warnings may be fine in a text file.)
