17247 Discussions
Controller with counter [CPU - help]
I have been assigned a task in my new course called VHDL (first time in VHDL environment) doing a simple CPU.
What I have done so far are the following (All simulated and working as expected):
  • ALU
  • Multiplexer
  • Registerfile
  • Buffer
  • ROM
  • RW-memory
The next part is to do a controller and a 16 bit programcounter
16 bit programcounter:
library ieee;use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_signed.all; use work.all; use CPU_package.all; entity Program_Counter is PORT(clk, reset : IN std_logic; counter_out : OUT std_logic_vector(15 downto 0)); end Program_Counter; architecture RTL of Program_Counter is Signal Counter : std_logic_vector(15 downto 0) := (others => '0'); begin process(reset, clk) begin if(reset = '1') then counter <= (others => '0'); elsif(rising_edge(clk)) then counter <= counter + '1'; end if; end process; counter_out <= counter; end RTL;
controller:
So far I've made:
  • Entity for the controller
  • In the architecture, Ive made different kind of states (refer to picture down)
However, this is the part where Im completely stuck at. I can't figure out how the programcounter should interact with the controller.
First state: "fetch instruction",
  1. they assign adr := pc and we do know that the adr is connected to both the RW-memory and RAM. In both these components the adr is used to choose which instruction to use (ROM) and also which register(like a big memory) we should read or write to (RW-memory).
    Something that seems strange to me is that according to the specs adr is 4 bit, while pc is 16 bit. Why?
  2. rw := 1. Are we supposed to assign it that value when we enter this state? As you can see this is a bit confusing to me.
Second state: "load instruction",
  1. I believe that after we have gone through the first state, the RW-memory or ROM will return some data (depends on which one is active) to us from its register, and this data is saved.
    If it is ROM giving us data -> example of an instruction could be : ldi&r3&"0011"
    If it is RW-memory it just contains 4 bits of data. I dont really know what this will give us in the next state.
Third state: "decode instruction",
  1. Now we are supposed to decode the instruction (= data).
    If it is from the ROM I can understand what we are supposed to decode, but not with information from RW-memory.
Fourth state: ---
  1. So depending on the state before, we enter one of these.
  • Write result - The result from the ALU should be written somewhere, perhaps in the fileregister?
  • Load data -
  • Store data -
  • Load immediate -
The last three, Im not sure what to do.
Next state: goes back to the first state
  1. Is this where the counter should increment with 1?
https://www.alteraforum.com/forum/attachment.php?attachmentid=7819
https://www.alteraforum.com/forum/attachment.php?attachmentid=7820
You dont have to give me explanations in detail, I could be satisfied with just some directions on what I should do.
Here is also a good page I've found http://www.nt-nv.fh-koeln.de/labor/vhdlenglish/kap8/k832.html
Please keep in mind that Im not interested in any codes, all Im asking is for a push in the right direction.
Cheers
The book Rapid Prototyping of Digital Systems. Humblen, Hall, Furman deals with a processor core written in VHDL in Chapter 8. Perhaps it is not the best book to learn vhdl but it has a lot of practical examples ( using altera kits ) and explain the processor in a easy way:
http://users.ece.gatech.edu/~hamblen/book/bookte.htm
Hi there Bertulus,
Do you have any documents that are free?
Cheers
I don't have a good pdf dealing with softcores and vhdl.
You have the instruction set. So the next step is define where it will be stored the program. If u are doing a core for academic purposes u may store it in a small rom inside the fpga. So define the size of the rom and the word size of this rom. And how the instructions will be code it on it.
Thanks Bertulus,
The problem has been solved. The instruction set was stored inside the architecture of the ROM that was made before.
And regarding the counter and the different states - Counter starts with 0 (goes from 0 - 15 ( Each round gives it a tick ), 4 bits) and when a signal called STEP goes high it goes through the different states.
However, one thing I'm not settled with is the RW in the second state. Is the RW supposed to get set to 1 by itself or should I have an in signal thats sets it?
Cheers
The R/W must be set to '1' automatically in the fetch state to load the opcode to the instruction register. The fpgas works in asynchronous fashion, so u will get the instruction opcode in the next clock edge after you set RW ( next state ). For example:
process...
begin
-- default value
est_next <= est_reg;
ir_next <= ir_reg;
addr_bus <= pc(3 downto 0); -- only 4 bits of program counter are valid
rw <= '1';
case fetch is
when fetch =>
est_next <= decode;
addr_bus <= pc_reg(3 downto 0);
ir_next <= data_bus;
rw <= '1';
when decode =>
if( ir_reg = .... -- here you go through different state according to the opcode.
