17266 Discussions
Converting MATLAB into VHDL
Hello everyone, I would like to convert a (Transfer function) code from (MATLAB) into (VHDL) code, but I get an error. Is it possible to do this? I have converted an (Adder Circuit) into (VHDL) but I cannot do it for (Transfer function).
Thank You
If we are to help you we need a bit more information.
How are you converting?
What are your errors?
Thank You, I have attached the MATLAB files (function and test bench) files below, but I think that the main problem is in the (test bench) file.
I am using (HDL Coder) from (MATLAB) to convert it into (VHDL).
Sorry, I have no idea how or why or what with matlab. What is the error? Maybe that will help others to help you further.
this (https://alteraforum.com/forum/showthread.php?t=58725) wouldn't be the same issue now, wouldn't it?
