Hi.
I am designing using a Cypress FX3 device (CYUSB3014-BZXC) and a Cyclone IV FPGA (EP4CE115F29C8). The FPGA has a external 50 MHz oscillator. The design should run @ 100 MHz. To do this I have an internal PLL to generate it. The FX3 device has a 32 bits source synchronous interface running @100MHz clock coming from the FPGA. The FX3 device receive the data center-aligned. As guidance for the port name I has the following ones:
module SLAVE_FIFO_STREAM_IN(
input CLOCK_50, //input clp 50 Mhz
inout FX3_DQ, //data bus
output FX3_faddr, //output fifo address
output FX3_slrd, //output read select
output FX3_slwr, //output write select
input FX3_flaga, //full flag
input FX3_flagb, //partial full flag
input FX3_flagc, //empty flag
input FX3_flagd, //empty partial flag
output FX3_sloe, //output output enable select
output FX3_CLK, //output clk 100 Mhz and 180 phase shift
output FX3_slcs, //output chip select
output FX3_pktend, //output pkt end
output FX3_PMODE,
output FX3_RESET,
output FX3_PMODE_2 //used for debugging
I already set the next into my design: 1) An altddio_out_component to shift the out clock 180° (Connected the datain_h(1'b0) and datain_l(1'b1) to make it) 2) I already set the output parallel interface as: "set_instance_assignment -name FAST_OUTPUT_REGISTER ON" 3) My SDC constraints are the next ones:
set_time_format -unit ns -decimal_places 3
# **************************************************************# Create Clock# **************************************************************
create_clock -name CLOCK_50M -period 20.000
create_generated_clock
-name CLOCK_100M
-multiply_by 2
-source }]
# **************************************************************# Create Generated Clock# **************************************************************
# Put a generated clock on output clock port to be referenced by set_output_delay constraints. Note the -invert option, which says the clock is being inverted on the way out. This is important# since Quartus doesn't recognize the DDR output with VCC/GND switched as inverting the clock
create_generated_clock -source }] -name CLOCK_FX3 -invert
set_false_path -to
# Constrain the PLL automatically
derive_pll_clocks -create_base_clocks
# **************************************************************# Set Clock Uncertainty# **************************************************************
derive_clock_uncertainty
# ################################################################################ Parameters# ###############################################################################
# Specify the maximum external clock delay to the FPGA
set FX3_CLKs_max 0# Specify the minimum external clock delay to the FPGA
set FX3_CLKs_min 0# Specify the maximum external clock delay to the external device
set FX3_CLKd_max 0# Specify the minimum external clock delay to the external device
set FX3_CLKd_min 0# Specify the maximum setup time of the external device
set FX3_tSU 2# Specify the minimum setup time of the external device
set FX3_tH 0.5# Specify the maximum board delay
set FX3_BD_max 0# Specify the minimum board delay
set FX3_BD_min 0
# Specify the maximum clock-to-out of the external device
set FX3_tCO_max 9# Specify the minimum clock-to-out of the external device
set FX3_tCO_min 2
# ################################################################################ Output constraints# ###############################################################################
set_output_delay -clock CLOCK_FX3 -max
set_output_delay -clock CLOCK_FX3 -min -add_delay
# ################################################################################ Input constraints# ###############################################################################
set_input_delay -clock CLOCK_FX3 -max
set_input_delay -clock CLOCK_FX3 -min
I have been reviewing the Timequest guides provided in the AlteraWiki and the corresponding manuals. But I cannot evacuate the next doubt: As the design has a clock offset of 180° between the launch and the latch clock, (relative to the outputs to the device) I do not know which is the right way to constraint this. I should use a set_multicycle_path command? The design has a synchonizer between the register coming from the external device, but I do not know how tell this to Timequest. I attached a zipped file for the design if this is easier to understand. Thanks in advance. Franco
