17264 Discussions
Counter implementation in Quartus II 7.2
Hi there,
This code http://www.altera.com/support/examples/verilog/ver-counter.html?gsa_pos=5&wt.oss_r=1&wt.oss=counter%20code
results the attached RTL view. I wonder why the Adder is used in this circuit. I would rather expect some T flip-flops. Am I doing something wrong?
Thank you very much in advance.
--- Quote Start ---
--- Quote End ---
You can only build an asynchronous ripple-carry counter from T flip-flops, almost useless for fast logic design. Or do you see, how the below logic, that describes the said synchronous counter could use T-flip-flops? The adder ist exactly implementing the line result = result + 1;
always @(posedge clk or posedge reset) begin if (reset) result = 0; else if (ena) result = result + 1; end
Ok. Thank you!
