17259 Discussions
Crash while compiling simple project for MAX V.
ricardoluz
I'm starting a new project, and did a simple top file.
When I try to compile it I get a crash error.
The report:
Problem Details Error: Internal Error: Sub-system: FYGR, File: /quartus/fitter/fygr/fygr_cdr_op.cpp, Line: 2875 source_oterm != NULLFitter pre-processing Stack Trace: 0x166916: FYGR_CDR_OP::emulatedLVDS_create_complementary_pin + 0x966 (fitter_fygr) 0x2ab39: FYGR_EXPERT::fitter_preparation + 0x6b9 (fitter_fygr) 0x23860: FYGR_FITCC_FAMILY_EXPERT::fitter_preparation + 0x40 (fitter_fygr) 0x557a1: FITCC_EXPERT::fitter_preparation + 0x1f1 (FITTER_FITCC) 0x56116: FITCC_EXPERT::invoke_fitter + 0x396 (FITTER_FITCC) 0x23af6: fygr_execute + 0x1a6 (fitter_fygr) 0xe910: fmain_start + 0x900 (FITTER_FMAIN) 0x41b1: qfit_execute_fit + 0x1bd (comp_qfit_legacy_flow) 0x5384: QFIT_FRAMEWORK::execute + 0x2a0 (comp_qfit_legacy_flow) 0x267f: qfit_legacy_flow_run_legacy_fitter_flow + 0x1c7 (comp_qfit_legacy_flow) 0x14410: TclInvokeStringCommand + 0xf0 (tcl86) 0x161e2: TclNRRunCallbacks + 0x62 (tcl86) 0x17a65: TclEvalEx + 0xa65 (tcl86) 0xa6f8b: Tcl_FSEvalFileEx + 0x22b (tcl86) 0xa5646: Tcl_EvalFile + 0x36 (tcl86) 0x12606: qexe_evaluate_tcl_script + 0x376 (comp_qexe) 0x11864: qexe_do_tcl + 0x334 (comp_qexe) 0x16755: qexe_run_tcl_option + 0x585 (comp_qexe) 0x380c3: qcu_run_tcl_option + 0x1003 (comp_qcu) 0x160aa: qexe_run + 0x39a (comp_qexe) 0x16e51: qexe_standard_main + 0xc1 (comp_qexe) 0x2233: qfit2_main + 0x73 (quartus_fit) 0x12e98: msg_main_thread + 0x18 (CCL_MSG) 0x1467e: msg_thread_wrapper + 0x6e (CCL_MSG) 0x16660: mem_thread_wrapper + 0x70 (ccl_mem) 0x12761: msg_exe_main + 0xa1 (CCL_MSG) 0x287e: __tmainCRTStartup + 0x10e (quartus_fit) 0x14033: BaseThreadInitThunk + 0x13 (KERNEL32) 0x73690: RtlUserThreadStart + 0x20 (ntdll)   End-trace     Executable: quartus_fit Comment: None   System Information Platform: windows64 OS name: Windows 10 OS version: 10.0   Quartus Prime Information Address bits: 64 Version: 18.1.0 Build: 625 Edition: Lite Edition
Tried googling it, and I don't get any information.
I never used an FPGA of this family.
I think the problem might be somewhere in the assigment of the pins.
Namely of the differential ones, because if i comment them it compiles without any crashes.
In previous designs with different devices, I used the primitive ALT_OUTBUF_DIFF whenever i need to output LVDS, but now it tells me it is not supported.
I tried using the megafunction ALTLVDS_TX, with a deserialization of 1 but the crash is still there.
These are the assignments:
set_global_assignment -name FAMILY "MAX V" set_global_assignment -name DEVICE 5M160ZE64A5 set_global_assignment -name TOP_LEVEL_ENTITY MAXV_i2c_top set_global_assignment -name ORIGINAL_QUARTUS_VERSION 18.1.0 set_global_assignment -name PROJECT_CREATION_TIME_DATE "09:56:31 APRIL 07, 2020" set_global_assignment -name LAST_QUARTUS_VERSION "18.1.0 Lite Edition" set_global_assignment -name PROJECT_OUTPUT_DIRECTORY output_files set_global_assignment -name MIN_CORE_JUNCTION_TEMP "-40" set_global_assignment -name MAX_CORE_JUNCTION_TEMP 125 set_global_assignment -name DEVICE_FILTER_PIN_COUNT 64 set_global_assignment -name ERROR_CHECK_FREQUENCY_DIVISOR "-1" set_location_assignment PIN_7 -to clock set_location_assignment PIN_2 -to reset set_location_assignment PIN_5 -to i2c_sda set_location_assignment PIN_10 -to i2c_scl set_location_assignment PIN_18 -to data_out[0] set_instance_assignment -name IO_STANDARD LVDS_E_3R -to data_out[0] set_location_assignment PIN_19 -to "data_out[0](n)" set_instance_assignment -name IO_STANDARD LVDS_E_3R -to data_out[1] set_location_assignment PIN_20 -to data_out[1] set_location_assignment PIN_21 -to "data_out[1](n)" set_instance_assignment -name IO_STANDARD LVDS_E_3R -to data_out[2] set_location_assignment PIN_22 -to data_out[2] set_location_assignment PIN_24 -to "data_out[2](n)" set_instance_assignment -name IO_STANDARD LVDS_E_3R -to data_out[3] set_location_assignment PIN_26 -to data_out[3] set_location_assignment PIN_27 -to "data_out[3](n)" set_instance_assignment -name IO_STANDARD LVDS_E_3R -to data_out[4] set_location_assignment PIN_30 -to data_out[4] set_location_assignment PIN_31 -to "data_out[4](n)" set_instance_assignment -name IO_STANDARD LVDS_E_3R -to data_out[5] set_location_assignment PIN_32 -to data_out[5] set_location_assignment PIN_33 -to "data_out[5](n)" set_instance_assignment -name IO_STANDARD LVDS_E_3R -to data_out[6] set_location_assignment PIN_35 -to data_out[6] set_location_assignment PIN_34 -to "data_out[6](n)" set_instance_assignment -name IO_STANDARD LVDS_E_3R -to data_out[7] set_location_assignment PIN_37 -to data_out[7] set_location_assignment PIN_36 -to "data_out[7](n)" set_instance_assignment -name IO_STANDARD LVDS_E_3R -to data_out[8] set_location_assignment PIN_44 -to data_out[8] set_location_assignment PIN_43 -to "data_out[8](n)" set_instance_assignment -name IO_STANDARD LVDS_E_3R -to data_out[9] set_location_assignment PIN_47 -to data_out[9] set_location_assignment PIN_46 -to "data_out[9](n)" set_instance_assignment -name IO_STANDARD LVDS_E_3R -to data_out[10] set_instance_assignment -name IO_STANDARD LVDS_E_3R -to data_out[11] set_instance_assignment -name IO_STANDARD LVDS_E_3R -to data_out[12] set_instance_assignment -name IO_STANDARD LVDS_E_3R -to data_out[13] set_instance_assignment -name IO_STANDARD LVDS_E_3R -to data_out[14] set_instance_assignment -name IO_STANDARD LVDS_E_3R -to data_out[15] set_location_assignment PIN_50 -to data_out[10] set_location_assignment PIN_49 -to "data_out[10](n)" set_location_assignment PIN_53 -to data_out[11] set_location_assignment PIN_52 -to "data_out[11](n)" set_location_assignment PIN_55 -to data_out[12] set_location_assignment PIN_54 -to "data_out[12](n)" set_location_assignment PIN_58 -to data_out[13] set_location_assignment PIN_56 -to "data_out[13](n)" set_location_assignment PIN_60 -to data_out[14] set_location_assignment PIN_59 -to "data_out[14](n)" set_location_assignment PIN_63 -to data_out[15] set_location_assignment PIN_61 -to "data_out[15](n)" set_instance_assignment -name IO_STANDARD "2.5 V" -to clock set_instance_assignment -name IO_STANDARD "2.5 V" -to i2c_scl set_instance_assignment -name IO_STANDARD "2.5 V" -to i2c_sda set_instance_assignment -name IO_STANDARD "2.5 V" -to reset set_global_assignment -name POWER_PRESET_COOLING_SOLUTION "NO HEAT SINK WITH STILL AIR" set_global_assignment -name TIMING_ANALYZER_MULTICORNER_ANALYSIS OFF set_global_assignment -name NUM_PARALLEL_PROCESSORS ALL set_global_assignment -name SDC_FILE MAXV_i2c.sdc set_global_assignment -name VERILOG_FILE MAXV_i2c_top.v set_global_assignment -name VERILOG_FILE i2c_control.v set_global_assignment -name DEVICE_MIGRATION_LIST 5M160ZE64A5 set_global_assignment -name QIP_FILE LVDS_TX.qip
What do you think I might be doing wrong?
Cheers,
Ricardo
KennyTan_Altera
Can you use the latest release of Quartus Prime 19.1?
Do you have a bunch of output ports that are stuck GND  and had assigning to an LVDS I/O standard?
KennyTan_Altera
Any update?
ricardoluz
Hi Kenny, sorry for not answering sooner.
It is not solved. However, in the end the output were not suppose to be LVDS (miscommunication with my team). I change them to single ended (LVTTL 3.3), and the crash stoped.
Cheers.
KennyTan_Altera
Yes, this problem occur because of the LVDS I/O standard was assign incorrectly. It was suppose to give an error rather than crash. I will file a documentation/kdb on this.
mattb351
I'm having similar issues on a MAX V 5M160ZE64I5 device. I can compile and fit a design when I assign an output pin on bank 2 to 2V5. When I change it to LVDS_E_3R Quartus crashes. I'm using Quartus 20.1 Lite. I'm assigning the pin (txdata) in the pin planner to pin 37 (positive diff pair pin) and when I set it to LVDS_E_3R the pin planner creates the txdata(n) pin on pin 36 which is correct. It sets the IO Standard to LVDS_E_3R. Then when I go back into Quartus and compile it I get the "Sorry! The Quartus Prime software quit unexpectedly." dialog box.
Any ideas? I've only been using Intel devices on this project, previously I have been using the X devices so I'm not sure if it's something I'm doing as a Quartus newb or this is actually a bug.
Problem Details
Error:
Internal Error: Sub-system: FYGR, File: /quartus/fitter/fygr/fygr_cdr_op_place.cpp, Line: 1930
get_io_mgr()->is_insertion_legal(atom, dev_pad_id)Fitter pre-processing
Stack Trace:
   0x17f41b: FYGR_CDR_OP::place_atom_at_gid + 0x29b (fitter_fygr)
   0x16a278: FYGR_CDR_OP::emulatedLVDS_placer + 0xc78 (fitter_fygr)
    0x2abef: FYGR_EXPERT::fitter_preparation + 0x6ff (fitter_fygr)
    0x238c0: FYGR_FITCC_FAMILY_EXPERT::fitter_preparation + 0x40 (fitter_fygr)
    0x55a73: FITCC_EXPERT::fitter_preparation + 0x203 (FITTER_FITCC)
    0x56414: FITCC_EXPERT::invoke_fitter + 0x3b4 (FITTER_FITCC)
    0x23b56: fygr_execute + 0x1a6 (fitter_fygr)
     0xeeab: fmain_start + 0x8eb (FITTER_FMAIN)
     0x4387: qfit_execute_fit + 0x1d3 (comp_qfit_legacy_flow)
     0x55e0: QFIT_FRAMEWORK::execute + 0x2b4 (comp_qfit_legacy_flow)
     0x2768: qfit_legacy_flow_run_legacy_fitter_flow + 0x1d4 (comp_qfit_legacy_flow)
    0x12877: qexe_evaluate_tcl_script + 0x367 (comp_qexe)
    0x11ac3: qexe_do_tcl + 0x343 (comp_qexe)
    0x16c34: qexe_run_tcl_option + 0x584 (comp_qexe)
    0x39285: qcu_run_tcl_option + 0xf95 (comp_qcu)
    0x1658d: qexe_run + 0x39d (comp_qexe)
    0x17371: qexe_standard_main + 0xc1 (comp_qexe)
     0x2262: qfit2_main + 0x82 (quartus_fit)
    0x13258: msg_main_thread + 0x18 (CCL_MSG)
    0x14a5e: msg_thread_wrapper + 0x6e (CCL_MSG)
    0x16af0: mem_thread_wrapper + 0x70 (ccl_mem)
    0x12af1: msg_exe_main + 0xa1 (CCL_MSG)
     0x2a02: __tmainCRTStartup + 0x10e (quartus_fit)
    0x17033: BaseThreadInitThunk + 0x13 (KERNEL32)
    0x4cec0: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Address bits: 64
Version: 20.1.1
Build: 720
