17263 Discussions
Create multiple generated clocks
My system have 360 channel input signal named: In_Target_Signal[359..0], they are used as clk in my project, and I have create clock for them as the following show:
create_clock -nam {In_Target_Signal} -period 10000.00 -waveform {0.000 5000.000} }] -add
I need to create a generated clock for each In_Target_Signal, that means I need to create 360 generated clocks: Generate_CLK[359..0].
Anybody tell me how to implement it?
Thanks in advance!
How about something like this in the SDC file:
for {set i 0} {$i<360} {incr i} {
create_clock
-period 10000.00
-name In_Target_Signal[$i]
[get_ports {In_Target_Signal[$i]}]
I have tried that, but timequest report that :
warning: Ignored assignment create_clock
There is no detailed info, so it is hard to find the reason. :(
I have solved the problem, the correct syntax is as below,FYI.
set FREQMeasure_Total_Channel 360
for {set loop 0} {$loop < $FREQMeasure_Total_Channel} {incr loop} {
puts "loop is $loop"
create_clock -name FREQMeasure_ChannleIn_Clk[$loop] -period 100000.000 FREQMeasure_ChannleIn[$loop]
