error when flash program
I use nios2 IDE6.0 to program my program to flash(am29lv160db)
but there is a error as follow:
#! /bin/sh
# this file was automatically generated by the nios ii ide flash programmer.
# it will be overwritten when the flash programmer options change.
cd e:/fpga/practise/uclinux/software/hello_world_0/debug
# creating .flash file for the project
$sopc_kit_nios2/bin/elf2flash --base=0x00000000 --end=0xfffff --reset=0x0 --inpu
t=hello_world_0.elf --output=cfi_flash.flash --boot=$sopc_kit_nios2/components/a
ltera_nios2/boot_loader_cfi.srec
# programming flash with the project
$sopc_kit_nios2/bin/nios2-flash-programmer --sidp=0x00201058 --id=4258846621 --t
imestamp=1201594370 --base=0x00000000 cfi_flash.flash
using cable "usb-blaster [usb-0]", device 1, instance 0x00
resetting and pausing target processor: ok
reading system id at address 0x00201058: verified
: checksumming existing contents
00000000 : reading existing contents
00004000 : reading existing contents
00006000 : reading existing contents
00008000 : reading existing contents
00010000 : reading existing contents
checksummed/read 59kb in 1.3s
00000000 ( 0%): erasing
00004000 (12%): erasing
00006000 (18%): erasing
00008000 (25%): erasing
00010000 (50%): erasing
erased 128kb in 0.9s (142.2kb/s)
00000000 ( 0%): programming
00004000 (12%): programming
00006000 (18%): programming
00008000 (25%): programming
00010000 (50%): programming
program failed at offset 10158
leaving target processor paused
can you tell me why I receive that error message and can you give some advice to solve it?
thank you!!!!
