When I attempt to generate a BSF using the following system verilog code, Quartus 20.1 Prime Lite is stripping the parentheses from the calculation of the output signal size. This results in an incorrect calculation of the size of the output (it is doing 4*2*8+24 = 88). However, it only does this on the BSF (see first attachment). Inside of my module, the size of the signal is correctly calculated as 4*2*(8+24) = 256.
Is this expected behavior for using BSF and BDF files? It's been several years and versions of Quartus since I used a BDF (>10 yrs) rather than doing everything in HDL.
If I use a text editor to edit the BSF file I can change the text to include parentheses and my system compiles (see second attachment). However, as soon I regenerate the BSF it overwrites the old text and is incorrect again.
module sync_adc_data #(
parameter integer STREAM_COUNT = 4,
parameter integer CHANNELS_PER_STREAM = 2,
parameter integer HEADER_WIDTH = 8,
parameter integer DATA_WIDTH = 24
input clk_i,
input rst_i,
output logic [((STREAM_COUNT * CHANNELS_PER_STREAM * (HEADER_WIDTH + DATA_WIDTH)) - 1) : 0] word_o
endmodule : sync_adc_data
链接已复制
Engineering has made preliminary plan to fix this issue in Quartus Standard version 21.1 which will be released around September. Until then you will have to use the workaround of editing the symbol after regenerating it.
With that being said, I will put this case to a close pending. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Nurina
