Creating
Hi, I have complete design (in bdf file). I want use this in other projects in design files. What I need generate? (File->Create/Update-> symbol and HDL file ?). Can Quartus generate library file? If yes, why?
Just create the symbol file (.bsf), add the directory with the .bsf and all the necessary source files to the new project file paths and place the symbol in the new project schematic. This is only exports the logic design, BEFORE synthesis and fitting... if you want to import\export part of a design AFTER fitting and\or synthesys things are more complicated
