17255 Discussions
Cyclone III SOPC and Intel Flash pin problem
I seem to be doing something pretty wrong when it comes to setting up my system with my Cyclone III starter kit. I am building an SOPC builder system, and use the "CFI Flash" component, and configure it with the "Intel 256P30" device. This seems straight forward enough.
When i go to the pin assignment section though, i have Address[24..1], data[15..0], read_n, select_n, and write_n outputs of my block in my top level schematic.
My problem is that the actual device has these pins:
we_n, ce_n, oe_n, reset_n, adv_n, clk, and wait signals.
The documentation of the CFI block assumes just 3 signals, but nothing about handling those other pins. The 103 page P30 Family flash document contains loads of different configurations for the flash device, synchronous, asynchronous, but I don't know how the CFI block is actually interfacing to the device.
I am sure there is something completely obvious I am missing, I would be very appreciative if someone could point it out to me.
-Art
The said synchronous flash interface pins exist as dedicated AP pins in Cyclone III, as the Configuration Handbook clarifies. So there shouldn't be a problem where to connect the pins. I don't know, if they are also supported by other flash related IP, apparently not in PFL Megafunction. This means, that the PFL access to Intel flash is asynchronous only.
what are "dedicated AP pins" ?
I have searched the Cyclone III Starter Kit : User Guide, Reference Manual, and Quick Start Guide. Also the Cyclone 3 Device Manual, and have seen no reference to an "AP pin", can you explain what that is?
I can connect write_n to we_n, and read_n to oe_n, and select_n to ce_n.
It looks like i want to just connect clk to 0, and adv_n to 0, and float the wait signal? From the picture. Does this sound right?
-Art
I assumed, that the flash is used for FPGA configuration, then the configuration scheme is active parallel (AP) and the flash has to use the dedicated pins. But I see that you didn't say a word about used configuration scheme.
If you don't use flash for configurations, simply follow the P30 handbook:.
--- Quote Start ---
If only asynchronous reads are to be performed, CLK should be tied to a valid VIH level, WAIT signal can be floated and ADV# must be tied to ground.
--- Quote End ---
Thank you. I think i get what you were saying.
-Art
