17252 Discussions
DAC with THDB-ADA on DE2-115
Hi there,
I'm working with DAC on the daughter board THDB-ADA. The pin assignments are correct, I believe, but the circuit doesn't seem to be working.
Here are my waveforms from ModelSim, can somebody give me some suggestion on what I did wrong?
https://www.alteraforum.com/forum/attachment.php?attachmentid=6876
fyi: I create the data output to the board from 0-16300-0... (so that it will be a triangle waveform)
I'm still doing and glad to here from you.
Thank you,
Tan
If your FPGA output is q[7:0], and signal before DAC is DAC_DA[13:0], try this----------
DAC_DA[13:0]={1'b0, ~q[7], q[6:0], 5'b00000}
I contect with technical support of THDB-ADA board. They said this board does not support DC output. I think maybe that means, if you want to get a rectangle like waveform, the shape of that will degrade or change.
Thank you very much :)
I'm think I know about this daugher board really well right now :)
The reason why this board doesn't receive the DC signal is that, if you have a look at the supplied schematic, there is a high pass filter (parallel RC) at every input. I calculated it to be 1.592 KHz. So, if someone would like to deal with voice frequency, they have to build a frequency amplifier interface.
The reason why I didn't get this to be solven before is that I was blindly believe their schimatic, in which the output-bit enables are inputs from that daughterboard, lol.
By the way, I'm using VHDL, not Verilog :D
We can discuss about this board if you like :)
Tan
I am so glad that there's someone who are working with this daughter board as well and so nice to share experence with me. So, thank you very much.
This daughter board really confused me a lot.
I am designing an OFDM communication system using DE2-115 FPGA and THDB-ADA daughter board. I thought I can use this daughter board to convert 8 bit parral signal to multi-amplitude annalog signal. But I found the output waveform are not rectangle like. Nowadays, I want to add the ADC in this daughter board to see I can can get the same signal after DAC and ADC. But I am not sure whether it can work.
BTW, I am using Verilog and my circuit knowledge is so poor that I sometimes cannot understand the schimatic.
I don't know much about OFDM. As far as I know, it's a system using many sub-carriers to transmit digital information. In case of that, I dont think it is impossible to get multiple frequency signals onto processing by that daughter board. However, the frequency for a carrier using DE2-115 for that ADC abd DAC, in my opinion, are, should be less than 6MHz to create a good waveform.
Here is a trick that I found myself (I'm sure there are at least 1 more using OBUF) that will be useful for you to deal with ADC and DAC on that board.
First, you create 2 25MHz clock by detectting the rising edge and falling edge of your main clock, like:
If risingedge, clockR = not clockR
If fallingedge, clockF = not clockF
Then use your clockF to drive the DAC clocks, Write signals, using clockR to drive ADC and the whole program. This is to avoid the clock skew when sometimes ADC samples first and DAC samples later, and vice versa (try to imagine here, I'm not cery good in explaining, try me if you dont understand)
Then, I'm sure your waveform will get no any distortion (if the output is clocked in your program)
Cheers,
Tan
I also developed an OFDM modem using the DE2-115 and terasic THDB board. I found that the most fool proof method was to look very closely at the pin assignments in the example projects provided with the THDB card, then replicate it perfectly in your project. Once you get the DAC and ADC up and running, it should be fairly straightforward to develop an OFDM module. You must simulate first though. You have almost no hope without simulating first. Do it in a modular fashion. An OFDM MODEM starts with the IFFT. Say you use a 128 subcarrier system, you need to pass to the IFFT 128 real and 128 imaginary samples, one by one. Say you use Binary Phase Shift Keying, each real and imaginary input represents a point on the constellation diagram. For BPSK, each complex point can encode only 1 bit because you set the imaginary input to zero. So you pass in the real input as, say, 1000 or -1000 (in decimal), and the imag input as zero. The IFFT then creates a real and imaginary 128 point time domain waveform which you must multiply by the cosine (for real) and sine (for imaginary) of the carrier frequency. The carrier is easy to generate using a Numerically Controlled Oscillator. Add the two waveforms, filter and send to the DAC.
Then, do the reverse process at the receiver (quadrature multiplication etc), input to FFT. You should get out the same as you put in to the IFFT at the transmitter. For coherent OFDM, the information is in the absolute positioning of the received constellation points, but for a number of reasons, you'll get variations in their positioning. To use coherent OFDM, you must try to get perfect timing and correct for rotations in the channel. If you are developing this system alone with little experience, I would recommend using DIFFERENTIAL encoding, where the information resides not in the absolute position of the received points, but in the difference between neighbouring subcarriers.
To offer you hope, however, all the tools for building an OFDM MODEM are in Quartus, but you need to take it step by step, simulate every step of the way and try to overcome problems one by one (at the transmitter: cyc pre insertion, at the receiver: timing (look at Schmidl Cox), demapping (look at Cordic algorithms). It's not an easy task for one person but it *is* possible.
Hi everyone:
I am trying to use the THDB Board to create a DAC. But I have a problem, I can see my square wave.I tried connecting all the jumpers in the configuration that the manual says but it doesn't work. The assignment pin I think is correct. Could you give a hit to use it??
Thank You
--- Quote Start ---
Hi everyone:
Thank You
--- Quote End ---
Follow this
your entity should have:
XOUT : out std_logic_vector(13 downto 0);
YOUT : out std_logic_vector(13 downto 0);
-- adc 14 bit data inputs
XIN : in std_logic_vector(13 downto 0);
YIN : in std_logic_vector(13 downto 0);
-- Setup ADC and DAC
DAC_MODE : out std_logic; -- DAC mode, 1 for dual
DAC_WRTA : out std_logic; -- Write signal Channel A
DAC_WRTB : out std_logic; -- Write signal Channel B
ADC_OEA : out std_logic; -- Channel A enable
ADC_OEB : out std_logic; -- Channel b enable
PLL_OUT_ADC : out std_logic_vector(1 downto 0);
PLL_OUT_DAC : out std_logic_vector(1 downto 0)); -- Clock from HSMC
your interface:
--Clock processing---------------------------
process(CLOCK_50)
begin
if falling_edge(CLOCK_50) then
clockF <= not(clockF);
end if;
if rising_edge(CLOCK_50) then
clockR <= not(clockR);
end if;
end process;
--DAC and ADC interface----------------------
PLL_OUT_ADC(0) <= clockR;
PLL_OUT_ADC(1) <= clockR;
PLL_OUT_DAC(0) <= clockF;
PLL_OUT_DAC(1) <= clockF;
DAC_WRTA <= clockF;
DAC_WRTB <= clockF;
DAC_MODE <= '1'; -- Dual mode
ADC_OEA <= '0';
ADC_OEB <= '0';
--your outputs
YOUT <= YIN;;
XOUT <= XIN;
The whole thing should work.
Here is pins the assignment
ADC_OEA Location PIN_T25
ADC_OEB Location PIN_T26
CLOCK_50 Location PIN_Y2
DAC_MODE Location PIN_H24
DAC_WRTA Location PIN_H23
DAC_WRTB Location PIN_M25
PLL_OUT_ADC[0] Location PIN_G23
PLL_OUT_ADC[1] Location PIN_G24
PLL_OUT_DAC[0] Location PIN_V24
PLL_OUT_DAC[1] Location PIN_V23
RESET Location PIN_AB28
XIN[0] Location PIN_T22
XIN[1] Location PIN_T21
XIN[2] Location PIN_R23
XIN[3] Location PIN_R22
XIN[4] Location PIN_R21
XIN[5] Location PIN_P21
XIN[6] Location PIN_P26
XIN[7] Location PIN_P25
XIN[8] Location PIN_N26
XIN[9] Location PIN_N25
XIN[10] Location PIN_L22
XIN[11] Location PIN_L21
XIN[12] Location PIN_U26
XIN[13] Location PIN_U25
XOUT[0] Location PIN_D27
XOUT[1] Location PIN_D28
XOUT[2] Location PIN_E27
XOUT[3] Location PIN_E28
XOUT[4] Location PIN_F27
XOUT[5] Location PIN_F28
XOUT[6] Location PIN_G27
XOUT[7] Location PIN_G28
XOUT[8] Location PIN_K27
XOUT[9] Location PIN_K28
XOUT[10] Location PIN_M27
XOUT[11] Location PIN_M28
XOUT[12] Location PIN_K21
XOUT[13] Location PIN_K22
YIN[0] Location PIN_V22
YIN[1] Location PIN_U22
YIN[2] Location PIN_V28
YIN[3] Location PIN_V27
YIN[4] Location PIN_U28
YIN[5] Location PIN_U27
YIN[6] Location PIN_R28
YIN[7] Location PIN_R27
YIN[8] Location PIN_V26
YIN[9] Location PIN_V25
YIN[10] Location PIN_L28
YIN[11] Location PIN_L27
YIN[12] Location PIN_J26
YIN[13] Location PIN_J25
YOUT[0] Location PIN_F24
YOUT[1] Location PIN_F25
YOUT[2] Location PIN_D26
YOUT[3] Location PIN_C27
YOUT[4] Location PIN_F26
YOUT[5] Location PIN_E26
YOUT[6] Location PIN_G25
YOUT[7] Location PIN_G26
YOUT[8] Location PIN_H25
YOUT[9] Location PIN_H26
YOUT[10] Location PIN_K25
YOUT[11] Location PIN_K26
YOUT[12] Location PIN_L23
YOUT[13] Location PIN_L24
You can use this to simulate a sine wave 2MHz
signal datax_s : std_logic_vector(13 downto 0);
constant len : integer := 100;
type data_array is array(natural range len-1 downto 0) of std_logic_vector(13 downto 0);
signal datax: data_array := (
"10000000000000","10111101101010","11101100000100","11111111101111",
"11110011110100","11001011001111","10010000000010","01010000111000",
"00011101010111","00000010010001","00000110010000","00101000011000",
"01100000001010","10011111110101","11010111100111","11111001101111",
"11111101101110","11100010101000","10101111000111","01101111111101",
"00110100110000","00001100001011","00000000010000","00010011111011",
"01000010010101","01111111111111","10111101101010","11101100000100",
"11111111101111","11110011110100","11001011001111","10010000000010",
"01010000111000","00011101010111","00000010010001","00000110010000",
"00101000011000","01100000001010","10011111110101","11010111100111",
"11111001101111","11111101101110","11100010101000","10101111000111",
"01101111111101","00110100110000","00001100001011","00000000010000",
"00010011111011","01000010010101","10000000000000","10111101101010",
"11101100000100","11111111101111","11110011110100","11001011001111",
"10010000000010","01010000111000","00011101010111","00000010010001",
"00000110010000","00101000011000","01100000001010","10011111110101",
"11010111100111","11111001101111","11111101101110","11100010101000",
"10101111000111","01101111111101","00110100110000","00001100001011",
"00000000010000","00010011111011","01000010010101","01111111111111",
"10111101101010","11101100000100","11111111101111","11110011110100",
"11001011001111","10010000000010","01010000111000","00011101010111",
"00000010010001","00000110010000","00101000011000","01100000001010",
"10011111110101","11010111100111","11111001101111","11111101101110",
"11100010101000","10101111000111","01101111111101","00110100110000",
"00001100001011","00000000010000","00010011111011","01000010010101"); -- 2MHz
create_signal_process: process(RESET,clockR)
begin
if RESET = '1' then
datax_s <= (others => '0');
elsif rising_edge(clockR) then
datax <= datax(len-2 downto 0) & datax(len-1);
datax_s <= datax(len-1);
end if;
XOUT <= datax_s;
end process;
XOUT (DAC channel A) should be a sinewave 2MHz
Thank you very much for your help. I will try to do this. I hope this time it works.
--- Quote Start ---
Follow this
your interface:
process(CLOCK_50)
begin
end if;
end if;
end process;
DAC_WRTA <= clockF;
DAC_WRTB <= clockF;
ADC_OEA <= '0';
ADC_OEB <= '0';
--your outputs
YOUT <= YIN;;
XOUT <= XIN;
--- Quote End ---
I tried to test the program. However it doesnt work. I am using the altera DE2 board and the terasic daughter board. I checked the pin assignment. I cant see anything in the output. Could you help me with this???
--- Quote Start ---
--- Quote End ---
Could you tell me how you set up your design?
If I will check the basic operation, I would set it like:
Use an SMA cable to connect the ADC channel A to a generator, say you're using a 1V, 500kHz sine wave.
Use another SMA cable for the DAC channel A to the osciloscope.
Make sure the contact between your THDB ADA to your DE2-115 is HSMC and is firm (pushing it down a bit hard)
If it doesn't work either, check the jumpers on your daughter board. Leave it as default if you've changed something. I'm curently not with my board so I can't check it.
If it doesn't work either, connect the data, XIN, to the LEDS to check if it works. If not, make sure to set the ADC_OEA to 0
--- Quote Start ---
Follow this
your interface:
process(CLOCK_50)
begin
end if;
end if;
end process;
DAC_WRTA <= clockF;
DAC_WRTB <= clockF;
ADC_OEA <= '0';
ADC_OEB <= '0';
--your outputs
YOUT <= YIN;;
XOUT <= XIN;
--- Quote End ---
Does this code work for a Cyclone IV? because I have different pin assigments and I'm using the De2-115 board and the data conversion HSMC.
--- Quote Start ---
--- Quote End ---
That works for DE2-115 (Cyclone IV, for more specific, Cyclone IV EP4CE115F29C7N) using HSMC THDB ADA
Hi ,
I have to interface my Cyclone 3 starter kit with my ADA_thdb board. Can anyone tell me how to proceed with? Are there any sort of constraints or specific things to be noted while interfacing the two boards. I do not wish to spoil my board by programming it in a wrong way.
So any guidelines on how to start with will be appreciated.
Please do enlighten this beginner.
Thanks in advance.
I don't have a Cyclone 3 board here. I'm not sure what is your interface between the FPGA board and the daughter board. Is it HSMC or GPIO? Can you upload the pictures or give me the web links of your boards?
First, use the FPGA board manual to obtain the pins for your interface. Make sure you can make a correct pins assignment.
Second, try the program I wrote above.
--- Quote Start ---
--- Quote End ---
Hi duytan ,
Ya sure , I am attaching the pics of the ADA borad .
--- Quote Start ---
--- Quote End ---
Hi duytan ,
Ya sure , I am attaching the pics of the ADA borad . It is the HSMC board , the first one in the attached pdf. And ya, i'll refer to the pins and keep the assignments ready. Will you be able to verify them for me?
Cyclone 3 Starter board link is here.
http://www.altera.com/products/devkits/altera/kit-cyc3-starter.html
Thanks !
Pins assignment for Cyclone 3 Starter Board
Assign this and try my code above
ADC_OEA Location PIN_T3
ADC_OEB Location PIN_R3
CLOCK_50 Location PIN_B9
DAC_MODE Location PIN_L1
DAC_WRTA Location PIN_T24
DAC_WRTB Location PIN_W25
PLL_OUT_ADC[0] Location PIN_V18
PLL_OUT_ADC[1] Location PIN_U18
PLL_OUT_DAC[0] Location PIN_C14
PLL_OUT_DAC[1] Location PIN_D14
RESET Location ==> Choose one of your switch
XIN[0] Location PIN_N13
XIN[1] Location PIN_M13
XIN[2] Location PIN_N6
XIN[3] Location PIN_M6
XIN[4] Location PIN_R18
XIN[5] Location PIN_R17
XIN[6] Location PIN_M14
XIN[7] Location PIN_L13
XIN[8] Location PIN_M17
XIN[9] Location PIN_L16
XIN[10] Location PIN_L18
XIN[11] Location PIN_K18
XIN[12] Location PIN_G18
XIN[13] Location PIN_G17
XOUT[0] Location PIN_T1
XOUT[1] Location PIN_N7
XOUT[2] Location PIN_N8
XOUT[3] Location PIN_J13
XOUT[4] Location PIN_N10
XOUT[5] Location PIN_N11
XOUT[6] Location PIN_K17
XOUT[7] Location PIN_P11
XOUT[8] Location PIN_B2
XOUT[9] Location PIN_B1
XOUT[10] Location PIN_G2
XOUT[11] Location PIN_G1
XOUT[13] Location PIN_K1
YIN[0] Location PIN_T18
YIN[1] Location PIN_T17
YIN[2] Location PIN_R4
YIN[3] Location PIN_R5
YIN[4] Location PIN_P18
YIN[5] Location PIN_P17
YIN[6] Location PIN_L15
YIN[7] Location PIN_L14
YIN[8] Location PIN_M18
YIN[9] Location PIN_L17
YIN[10] Location PIN_H18
YIN[11] Location PIN_H17
YIN[12] Location PIN_E18
YIN[13] Location PIN_E17
YOUT[0] Location PIN_M3
YOUT[1] Location PIN_T2
YOUT[2] Location PIN_H15
YOUT[3] Location PIN_H16
YOUT[4] Location PIN_N16
YOUT[5] Location PIN_N15
YOUT[6] Location PIN_R16
YOUT[7] Location PIN_T16
YOUT[8] Location PIN_C2
YOUT[9] Location PIN_C1
YOUT[10] Location PIN_H2
YOUT[11] Location PIN_H1
YOUT[12] Location PIN_K5
YOUT[13] Location PIN_L5
Hi tan,
I am currently creating a spread-sheet for the pin assignments. Well thanks a lot! i'll verify my assignments with what you have sent. I have another doubt,
The ADA board feature list mentions the following:
The feature set of the ADA is listed below:
1. Dual AD channels with 14-bit resolution and data rate up to 65 MSPS
2. Dual DA channels with 14-bit resolution and data rate up to 125 MSPS
3. Dual interfaces include HSMC and GPIO, which are fully compatible with Cyclone III Starter
Kit and DE1/DE2/DE2_70/DE2_115/DE3/DE4, respectively
4. Clock sources include oscillator 100MHz, SMA for AD and DA each, and PLL from either
HSMC or GPIO interface
5. AD converter analog input range 2V p-p range.
6. DA converter output voltage range 2V p-p range.
7. DA and AD converters do not support DC signaling
The entire board operates on DC-signaling if am not wrong, as our board is powered by an adapter. So what does it exactly mean by
DA and AD converters do not support DC signalling?
Also i think there is a mistake in the pins wrt_a and wrt_b as there is no pin such as T24 and W25 available.
Am attaching the schematics of Cyclone 3 Starter Board for your reference.
thanks!
ivads
If you are quite familiar with ADC and DAC, you will see that we need to adjust the gain value which is to adjust the converter into the amplitude of our signal. Well, don't mind if you don't understand what I've just said. I'm not a good explainer.
In other words, a signal source usually includes DC and AC component. It's like you have a sine wave but it is shifted up or down around the zero. It is because that sine wave is added to a DC component. That is very "annoying" in signal processing as it consumes power when processing, causing heat, reducing the accuracy of the represented binary, adding truncating noise to your signal when processing.
Any way, that statement means, you can only put AC signal into you SMA cable (for ADC) and create an AC signal (DAC)
Also, when you apply the signal onto your daughterboard, your DC component will be filtered out.
And by they way, I dont think you broke your board, it's maybe because of the contact between your board and daughterboad was not tight. Try to push them toghther harder
