17255 Discussions
DDR 3 controller clocks usage
Hi
I'm trying to use the DDR 3 controller on the Arria II eval board.
when I instantiate it in the SOPC builder it creates several clocks.
what clock should I use to drive other parts of the design in order to stay synchronous with the DDR III?
thanks in advance
I assume that you are going to use the avalon-mm interface in the controller to connect with other modules, so in this case you may find the afi_clk or afi_half_clk is useful.
