error
Error (10500): VHDL syntax error at uppgift4a_synkron.vhd(50) near text "process"; expecting "case"
Error (10500): VHDL syntax error at uppgift4a_synkron.vhd(86) near text "process"; expecting "if"
whats the problem? - it clearly tells you what the errors are. And you didnt post the code.
library ieee;
use ieee.std_logic_1164.all;
entity uppgift4a_synkron is
port (
-- Insignaler
CLOCK, reset_n : IN std_logic;
KEY_0, KEY_1 : IN std_logic;
-- Utsignaler
LEDG_0, LEDG_1 : OUT std_logic);
end entity;
architecture rtl of uppgift4a_synkron is
-- Build an enumerated type for the state machine
type state_type is (oppen,stangd);
-- Register to hold the current state
signal state : state_type;
begin
process (reset_n, CLOCK)
begin
if reset_n = '0' then
state <= oppen;
LEDG_0 <= '0';
LEDG_1 <= '0';
elsif rising_edge(CLOCK) then
case state is
when oppen => if KEY_0 ='1' then
end if;
end process;
begin
case state is
when oppen=> if KEY_0='1' then
LEDG_0 <='0';
else
LEDG_0 <='1';
end if;
LEDG_1 <='0';
when stangd=>if KEY_1='1'then
LEDG_0 <='1';
elsif
LEDG_0= '0' then
LEDG_0 <='0';
else
LEDG_0 <='1';
end if;
LEDG_1 <='1';
end case;
end process;
end;
Here is the rest im so sorry
oppen=open and
stangd=closed
See that part of your code:
case state is
when oppen => if key_0 ='1' then
end if;
end process;
begin
case state is
You close the process with end process and then you have a begin. Begin what? Probably a process, so:
case state is
end if;
end process;
process(....)
begin
case state is
...etc
library ieee;
port (
-- Insignaler
-- Utsignaler
end entity;
begin
begin
state <= oppen;
LEDG_0 <= '0';
LEDG_1 <= '0';
case state is
end case;
end if;
end process;
process (state)
begin
case state is
oppen <='0';
else
oppen <='1';
end if;
stangd <='0';
oppen <='1';
else
oppen <='1';
end if;
stangd <='1';
end case;
end process;
end;
I wonder what is wrong in this code and dont be sarcastic show me instead :confused:
error>Error (10500): VHDL syntax error at uppgift4a_synkron.vhd(48) near text "case"; expecting "if"
Error (10500): VHDL syntax error at uppgift4a_synkron.vhd(51) near text "process"; expecting "case"
Error (10500): VHDL syntax error at uppgift4a_synkron.vhd(83) near text "process"; expecting "if"
oppen=open and
stangd=closed
--- Quote End ---
You havent closed an if in your code.
end if; --you forgot this
end case;
In the code you posted, there is an issue in the first process. I am posting the change with coments so it is easier for you to see. Good code formatting can go a long way to preventing these problems. (that and a good editor with syntax highlighting)
library ieee; use ieee.std_logic_1164.all; entity uppgift4a_synkron is port ( -- Insignaler CLOCK, reset_n : IN std_logic; KEY_0, KEY_1 : IN std_logic; -- Utsignaler LEDG_0, LEDG_1 : OUT std_logic ); end entity; architecture rtl of uppgift4a_synkron is -- Build an enumerated type for the state machine type state_type is (oppen,stangd); -- Register to hold the current state signal state : state_type; begin process (reset_n, CLOCK) begin if reset_n = '0' then state <= oppen; LEDG_0 <= '0'; LEDG_1 <= '0'; elsif rising_edge(CLOCK) then case state is when oppen => if KEY_0 ='1' then end if; --THIS LINE WAS NOT HERE end case; end if; end process; process (state) begin case state is when oppen=> if KEY_0='1' then oppen <='0'; else oppen <='1'; end if; stangd <='0'; when stangd=> if KEY_1='1'then oppen <='1'; else oppen <='1'; end if; stangd <='1'; end case; end process; end;
