Error (10500): VHDL syntax error at uppgift4a_synkron.vhd(50) near text "process"; expecting "case"
Error (10500): VHDL syntax error at uppgift4a_synkron.vhd(86) near text "process"; expecting "if"Link Copied
whats the problem? - it clearly tells you what the errors are. And you didnt post the code.
library ieee;
use ieee.std_logic_1164.all; entity uppgift4a_synkron is port ( -- Insignaler CLOCK, reset_n : IN std_logic; KEY_0, KEY_1 : IN std_logic; -- Utsignaler LEDG_0, LEDG_1 : OUT std_logic); end entity; architecture rtl of uppgift4a_synkron is -- Build an enumerated type for the state machine type state_type is (oppen,stangd); -- Register to hold the current state signal state : state_type; begin process (reset_n, CLOCK) begin if reset_n = '0' then state <= oppen; LEDG_0 <= '0'; LEDG_1 <= '0'; elsif rising_edge(CLOCK) then case state is when oppen => if KEY_0 ='1' then end if; end process; begin case state is when oppen=> if KEY_0='1' then LEDG_0 <='0'; else LEDG_0 <='1'; end if; LEDG_1 <='0'; when stangd=>if KEY_1='1'then LEDG_0 <='1'; elsif LEDG_0= '0' then LEDG_0 <='0'; else LEDG_0 <='1'; end if; LEDG_1 <='1'; end case; end process; end; Here is the rest im so sorry oppen=open and stangd=closed- Mark as New
See that part of your code:
case state iswhen oppen => if key_0 ='1' then
end if;
end process;
begin
case state is
You close the process with end process and then you have a begin. Begin what? Probably a process, so: case state is
end if;
end process;
process(....)
begin
case state is
...etc
library ieee;
use ieee.std_logic_1164.all; entity uppgift4a_synkron is port ( -- Insignaler CLOCK, reset_n : IN std_logic; KEY_0, KEY_1 : IN std_logic; -- Utsignaler LEDG_0, LEDG_1 : OUT std_logic); end entity; architecture rtl of uppgift4a_synkron is -- Build an enumerated type for the state machine type state_type is (oppen,stangd); -- Register to hold the current state signal state : state_type; begin process (reset_n, CLOCK) begin if reset_n = '0' then state <= oppen; LEDG_0 <= '0'; LEDG_1 <= '0'; elsif rising_edge(CLOCK) then case state is when oppen => if KEY_0 ='1' then end case; end if; end process; process (state) begin case state is when oppen=> if KEY_0='1' then oppen <='0'; else oppen <='1'; end if; stangd <='0'; when stangd=>if KEY_1='1'then oppen <='1'; else oppen <='1'; end if; stangd <='1'; end case; end process; end; I wonder what is wrong in this code and dont be sarcastic show me instead :confused: error>Error (10500): VHDL syntax error at uppgift4a_synkron.vhd(48) near text "case"; expecting "if" Error (10500): VHDL syntax error at uppgift4a_synkron.vhd(51) near text "process"; expecting "case" Error (10500): VHDL syntax error at uppgift4a_synkron.vhd(83) near text "process"; expecting "if" oppen=open and stangd=closed --- Quote End ---- Mark as New
You havent closed an if in your code.
when oppen => if KEY_0 ='1' then end if; --you forgot this end case;- Mark as New
In the code you posted, there is an issue in the first process. I am posting the change with coments so it is easier for you to see. Good code formatting can go a long way to preventing these problems. (that and a good editor with syntax highlighting)
library ieee;
port (
-- Insignaler
-- Utsignaler
end entity;
begin
begin
state <= oppen;
LEDG_0 <= '0';
LEDG_1 <= '0';
case state is
when oppen =>
if KEY_0 ='1' then
end if; --THIS LINE WAS NOT HERE
end case;
end if;
end process;
process (state)
begin
case state is
when oppen=>
if KEY_0='1' then
oppen <='0';
else
oppen <='1';
end if;
stangd <='0';
when stangd=>
if KEY_1='1'then
oppen <='1';
else
oppen <='1';
end if;
stangd <='1';
end case;
end process;
end;
Topic Options
