17261 Discussions
DDR2 memory design failed
Generated a test case from external memory IP for DDR2 design, When I ran the design in QuartusII, it is giving error message as follows, Can some help me with the case...I looked into the Altera Web but i couldn't find solution.
Error: Cannot place pin mem_clk[0] to location J16
Error: Can't place VREF pin L14 (VREFGROUP_B5_N0) for pin mem_clk[0] of type bi-directional with SSTL-18 Class I I/O standard at location J16
Error: Too many output and bidirectional pins per VCCIO and ground pair in I/O bank 5 when the VREF pin L14 (VREFGROUP_B5_N0) is used on device EP3C10F256C7 -- no more than 9 output/bidirectional pins within 14 consecutive pads are allowed when the voltage reference pins are driving in, but there are potentially 12 pins driving out.
It seems you designed the pcb yourself, may be you have to redesign it.
The SSTL-18 IO can not be used freely as you want, the numbers in each bank you can use are limited.
Refer to chapter 8 in Cyclone III Device Handbook Volume 1, especially Table 8–5 and related descriptions.
Hi loywong,
thanks for your feedback, But I couldn't find table 8-5 in cyclone III handbook. It seems that the table is removed in latest version of Document. Can you point me to exact table number. I assume it is 8-1/8-2 which describes about Cyclone III/Cyclone III LS Device DQS and DQ Bus Mode Support for Each Side of the Device. But I am following all the rules mentioned in that table.
Here I am attaching the QSF you can have a look.
Oh, you are right, it is table 8-1 now, my handbook is out of date.
In you qsf file:
--- Quote Start ---
set_location_assignment PIN_L14 -to mem_addr[12]
--- Quote End ---
you can not use L14 as an IO, it is the REFERENCE VOLTAGE INPUT for VREFB5. SSTL is a kind of persudo differential IO standard, a group of SSTL io must have a common reference voltage. You must connect it to a 0.9V voltage source for you are using the VREFB5 group(some of your DQ, DQS, ADDR... are SSTL IOs in this group).
Anothor thing I found:
--- Quote Start ---
set_location_assignment PIN_J16 -to mem_clk[0]
set_location_assignment PIN_K16 -to mem_clk_n[0]
--- Quote End ---
while in 3C10's pin-outs file they are:
DIFFIO_R7n
DIFFIO_R8n
not a differential pair.
I think you shoud place them in a same differential pair.
