17260 Discussions
How to constrain output for SRAM in TimeQuest?
There are examples about source synchronous design such as SDRAM time constrain, but I wonder how to constrain output for SRAM in TimeQuest?
eg. no clock needed for SRAM, but you must point a clock in the Set Output/Input Delay setup.
The SRAM data is changed with SRAM address latch in read process, but is it right to set the address as clock?
Thanks very much!
There should be a write_enable that does the write, so for writes I consider that the clock and constrain address/data in relation to it.
