17268 Discussions
DDR3 SDRAM Controller with UniPHY Intel FPGA IP (altera_mem_if_ddr3_emif)でMT41K256M16TW-107 IT:P は使用可能ですか。 Memory parameters/Memory Initialization Option/Memory CAS latency setting Memory CAS latency setting = 13 に設定できません。設定方法を教えてください。
KJalte2
QuartusII 19.1.0 Standard Edition
Device : 5CGXFC7C6F23C6N
BoonT_Intel
Hi Sir,
As you can see from the GUI, the allowed Memory CAS latency setting is from 5 - 11 only. So, you cannot set it to 13.
