17258 Discussions
De2 Verilog HDL LCD coding problem
Good day. we are currently doing a project using altera de2 that requires us to use the lcd. we have 3 .v files and VErilog3 is our top module.
module Verilog3( //////// CLOCK ////////// CLOCK_50, //////// KEY ////////// KEY, //////// LCD ////////// LCD_BLON, LCD_DATA, LCD_EN, LCD_ON, LCD_RS, LCD_RW, ); //======================================================= // PORT declarations //======================================================= //////////// CLOCK ////////// input CLOCK_50; //////////// KEY ////////// input KEY; //////////// LCD ////////// output LCD_BLON; inout LCD_DATA; output LCD_EN; output LCD_ON; output LCD_RS; output LCD_RW; reg Cont; wire DLY_RST; assign LCD_ON = 1'b1; assign LCD_BLON = 1'b1; always@(posedge CLOCK_50 or negedge KEY) begin if(!KEY) Cont <= 0; else Cont <= Cont+1; end lcd_test u0 ( // Host Side .iCLK ( CLOCK_50 ), .iRST_N ( DLY_RST ), // LCD Side .LCD_DATA ( LCD_DATA ), .LCD_RW ( LCD_RW ), .LCD_EN ( LCD_EN ), .LCD_RS ( LCD_RS ) , ); endmodule
module lcd_test ( // Host Side iCLK,iRST_N, // LCD Side LCD_DATA,LCD_RW,LCD_EN,LCD_RS ); // Host Side input iCLK,iRST_N; // LCD Side output LCD_DATA; output LCD_RW,LCD_EN,LCD_RS; // Internal Wires/Registers reg LUT_INDEX; reg LUT_DATA; reg mLCD_ST; reg mDLY; reg mLCD_Start; reg mLCD_DATA; reg mLCD_RS; wire mLCD_Done; parameter LCD_INTIAL = 0; parameter LCD_LINE1 = 5; parameter LCD_CH_LINE = LCD_LINE1+16; parameter LCD_LINE2 = LCD_LINE1+16+1; parameter LUT_SIZE = LCD_LINE1+32+1; always@(posedge iCLK or negedge iRST_N) begin if(!iRST_N) begin LUT_INDEX <= 0; mLCD_ST <= 0; mDLY <= 0; mLCD_Start <= 0; mLCD_DATA <= 0; mLCD_RS <= 0; end else begin if(LUT_INDEX<LUT_SIZE) begin case(mLCD_ST) 0: begin mLCD_DATA <= LUT_DATA; mLCD_RS <= LUT_DATA; mLCD_Start <= 1; mLCD_ST <= 1; end 1: begin if(mLCD_Done) begin mLCD_Start <= 0; mLCD_ST <= 2; end end 2: begin if(mDLY<18'h3FFFE) mDLY <= mDLY+1; else begin mDLY <= 0; mLCD_ST <= 3; end end 3: begin LUT_INDEX <= LUT_INDEX+1; mLCD_ST <= 0; end endcase end end end always begin case(LUT_INDEX) // Initial LCD_INTIAL+0: LUT_DATA <= 9'h038; LCD_INTIAL+1: LUT_DATA <= 9'h00C; LCD_INTIAL+2: LUT_DATA <= 9'h001; LCD_INTIAL+3: LUT_DATA <= 9'h006; LCD_INTIAL+4: LUT_DATA <= 9'h080; // Line 1 LCD_LINE1+0: LUT_DATA <= 9'h120;// LCD_LINE1+1: LUT_DATA <= 9'h120;// LCD_LINE1+2: LUT_DATA <= 9'h120;// LCD_LINE1+3: LUT_DATA <= 9'h120;// LCD_LINE1+4: LUT_DATA <= 9'h153;// S LCD_LINE1+5: LUT_DATA <= 9'h169;// i LCD_LINE1+6: LUT_DATA <= 9'h167;// g LCD_LINE1+7: LUT_DATA <= 9'h16E;// n LCD_LINE1+8: LUT_DATA <= 9'h161;// a LCD_LINE1+9: LUT_DATA <= 9'h174;// t LCD_LINE1+10: LUT_DATA <= 9'h175;// u LCD_LINE1+11: LUT_DATA <= 9'h172;// r LCD_LINE1+12: LUT_DATA <= 9'h165;// e LCD_LINE1+13: LUT_DATA <= 9'h120;// LCD_LINE1+14: LUT_DATA <= 9'h120;// LCD_LINE1+15: LUT_DATA <= 9'h120;// // Change Line LCD_CH_LINE: LUT_DATA <= 9'h0C0; // Line 2 LCD_LINE2+0: LUT_DATA <= 9'h120;// LCD_LINE2+1: LUT_DATA <= 9'h120;// LCD_LINE2+2: LUT_DATA <= 9'h156;// V LCD_LINE2+3: LUT_DATA <= 9'h165;// e LCD_LINE2+4: LUT_DATA <= 9'h172;// r LCD_LINE2+5: LUT_DATA <= 9'h169;// i LCD_LINE2+6: LUT_DATA <= 9'h166;// f LCD_LINE2+7: LUT_DATA <= 9'h169;// i LCD_LINE2+8: LUT_DATA <= 9'h163;// c LCD_LINE2+9: LUT_DATA <= 9'h161;// a LCD_LINE2+10: LUT_DATA <= 9'h174;// t LCD_LINE2+11: LUT_DATA <= 9'h169;// i LCD_LINE2+12: LUT_DATA <= 9'h16F;// o LCD_LINE2+13: LUT_DATA <= 9'h16E;// n LCD_LINE2+14: LUT_DATA <= 9'h120;// LCD_LINE2+15: LUT_DATA <= 9'h120;// default: LUT_DATA <= 9'hxxx; endcase end LCD_Controller u0 ( // Host Side .iDATA(mLCD_DATA), .iRS(mLCD_RS), .iStart(mLCD_Start), .oDone(mLCD_Done), .iCLK(iCLK), .iRST_N(iRST_N), // LCD Interface .LCD_DATA(LCD_DATA), .LCD_RW(LCD_RW), .LCD_EN(LCD_EN), .LCD_RS(LCD_RS) ); endmodule
module LCD_Controller ( // Host Side iDATA,iRS, iStart,oDone, iCLK,iRST_N, // LCD Interface LCD_DATA, LCD_RW, LCD_EN, LCD_RS ); // CLK parameter CLK_Divide = 16; // Host Side input iDATA; input iRS,iStart; input iCLK,iRST_N; output reg oDone; // LCD Interface output LCD_DATA; output reg LCD_EN; output LCD_RW; output LCD_RS; // Internal Register reg Cont; reg ST; reg preStart,mStart; ///////////////////////////////////////////// // Only write to LCD, bypass iRS to LCD_RS assign LCD_DATA = iDATA; assign LCD_RW = 1'b0; assign LCD_RS = iRS; ///////////////////////////////////////////// always@(posedge iCLK or negedge iRST_N) begin if(!iRST_N) begin oDone <= 1'b0; LCD_EN <= 1'b0; preStart<= 1'b0; mStart <= 1'b0; Cont <= 0; ST <= 0; end else begin ////// Input Start Detect /////// preStart<= iStart; if({preStart,iStart}==2'b01) begin mStart <= 1'b1; oDone <= 1'b0; end ////////////////////////////////// if(mStart) begin case(ST) 0: ST <= 1; // Wait Setup 1: begin LCD_EN <= 1'b1; ST <= 2; end 2: begin if(Cont<CLK_Divide) Cont <= Cont+1; else ST <= 3; end 3: begin LCD_EN <= 1'b0; mStart <= 1'b0; oDone <= 1'b1; Cont <= 0; ST <= 0; end endcase end end end endmodule
unfortunately when we synthesize it with our board, the display is dark and the 2nd line of our text is not displayed unless a certain button is pushed. can anyone help me fix our problem?we are using quartus ii 13.0.
thanks in advance
I think you should use SignalTap II tool for debugging your problem.
Long.
The DLY_RST is not connected to anything at the top level. Maybe it should be driven by the Cont register?
Have you tried simulation? I think it is a simple state machine that you can validate its functions in modelsim. Note that the always for case LUT_INDEX is missing sensitivity list at the always.
Either become always @ (*) or always @ (LUT_INDEX)
