Design Assistant
Hi, i have a question to the Quartus II Design Assistant.
In my design there is a reset synchronisation like this:
https://www.alteraforum.com/forum/attachment.php?attachmentid=7363
"async_res_in_n" is the asynchrounous external reset pin of my board and "sync_res_out_n" feeds all other registers in my designs.
This is what the Design Assistant wants to see.
But i always got the Warning Message:
Rule R102: External reset signals should be synchronized using two cascaded registers. Found 1 node(s) related to this rule.
Any idea ?
Have the same warning in my current design. On a reset signal that is syncronized with two cascaded registers.
You probably can ignore it (Disable rule/Suppress).
Thank you, I think the same
