17256 Discussions
Design Example Error in Compilation
pdewanga
Hi community,
I want to generate the binary file for Avalon streaming PCI HIP Design example on the device 1SG10MHN3F74C2LG.
I am following the steps given in -
L- and H-tile Avalon® Streaming and Single Root I/O Virtualization (SRIOV) Intel® FPGA IP for PCI Express* User Guide
- > 2.4. Generating the Design Example
    In step No.  15. Compile the example design project to generate the .sof file for the complete example design........
This step 15 I am getting the error in Quartus GUI as -
  • Error(22819): The option assigned for assignment (USE_PWRMGT_SCL : SDM_IO14) is not supported.
  • Error(22819): The option assigned for assignment (USE_PWRMGT_SDA : SDM_IO11) is not supported.
Where to get the correct assignment for 10M devices?  I am using Quartus 23.1 version.
-Piyush
Wincent_Altera
Hi Piyush,
You can comment out offending statement in the QSF to bypass this error message
for example setting "set_global_assignment -name USE_PWRMGT_SCL : SDM_IO14
Wincent_Intel
Wincent_Altera
Hi Piyush,
Wincent_Intel
Wincent_Altera
Hi Piyush,
Wincent_Intel
Wincent_Altera
I wish to follow up with you about this case.
Do you have any further questions on this matter ?
​​​​​​​Else I would like to have your permission to close this forum ticket
Wincent_Intel
Wincent_Altera
Hi
We have not hear from you and this Case is idling. It is not recommended to idle for too long.
Therefore following our support policy, I have to put this case in close status. My apologies if any inconvenience cause
Hence, This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If your support experience falls below a 9 out of 10, I kindly request the opportunity to rectify it before concluding our interaction. If the issue cannot be resolved, please inform me of the cause so that I can learn from it and strive to enhance the quality of future service experiences.
Wincent_Intel
