** Error: (vsim-3033)
Elias97
Hello, good afternoon, I am writing this post to ask you about an error that modelsim gives me when simulating my project, in which I am using two components: PLL intel fpga ip and PLL Reconfig intel fpga ip, these two components were generated from the Quartus 18.0 library and I made a top level in which I instantiated the two previously named components. The project synthesizes well and does not give errors, but when performing the simulation, I select the top level to simulate and it gives me this error: # ** Error: (vsim-3033) /build/swbuild/SJ/nightly/18.0std/614/l64/work/modelsim/eda/sim_lib/altera_lnsim.sv(27863): Instantiation of 'cyclonev_ffpll_reconfig' failed. The design unit was not found.
ShengN_Intel
Done simulation. Check the file and image attached. Go to folder simulation -> modelsim -> execute test_run_msim_rtl_vhdl.do in modelsim.
Do make sure IP .sip file are included for compilation.
If still got error, modify the test_run_msim_rtl_vhdl.do like below:
Uncommented (#) this line vcom -93 -work work {Z:/test/pll_modelsim/pllreconfig.vho}
Suppress error (vsim-10000): vsim -suppress 10000 -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L cyclonev -L rtl_work -L work -L pllreconfig -L pllreconfig -voptargs="+acc" PLLS_tb
Then execute the modified test_run_msim_rtl_vhdl.do in modelsim.
Sheng
Elias97
Sorry for the inconvenience, but the solution is not acceptable, since the project would stop being portable, because for the simulation to work I have to modify the .do file so that it correctly routes my folders, do you have any other solution for avoid that problem?
Elias97
 Thank you very much for the help, I managed to solve it. What was the change I made to fix it?
