17267 Discussions
Design Space Explorer issue
I'm using Quartus II 14.1 64b and DSE II launched from Quartus gui. Running on Centos 7 Linux.
When I try to run DSE (for a seed sweep) from its gui, I get the following error
Traceback (most recent call last):
File "<string>", line 22, in <module>
File "explorer.py", line 1379, in main
File "explorer.py", line 1286, in main_impl
File "explorer.py", line 346, in run
AttributeError: 'Explorer' object has no attribute 'server_url'
Design Space Explorer finished
Found info that says DSE II wants to use a local server but I'm at a loss as to what I need to do to get the tool to run. DSE II seems to be quite new and documentation is a bit sparse.
Any thoughts/help would be appreciated.
RMowb
Did you have any luck with this -- I have same issue and stuck as to where to start...
