Detecting preamble
Hello, I am trying to write a program to detect preamble of the attached signal. I am getting "error 10500:VHDL syntax error" for following code in Quartus. Can anyone correct me? As I am new to VHDL, I am unable to find it :cry:
Thanks in advance
Note: we are interested in only 8 bit preamble and 2 bit data (not whole 112 bit data).
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
package preamble is
constant NROF_CYCLES_per_interval: integer :=25;
constant NROF_INTERVALS: integer :=18;
constant NROF_ALL_CYCLES_MAX: integer :=NROF_CYCLES_per_interval*NROF_INTERVALS;
Variable cycle, all_cycles, nrof_cycles: integer :=0;
type Input_values is ARRAY (nrof_cycles) of integer;
function increment_cycle return integer;
function process1 (valu :integer) return integer;
function increment_all_cycles return integer;
function add_to_all_cycles (a: integer) return integer;
function contents_process(contents: integer) return integer;
end preamble;
package body preamble is
return integer is
begin
if (cycle +1 > nrof_cycles) then
return 1;
else
return cycle+1;
end if;
end increment_cycle;
function process1 (values: integer)
return integer is
variable myinput_values : input_values;
Variable SUM_A,SUM_B: integer :=0;
begin
cycle:=increment_cycle;
nrof_cycle:=nrof_cycle+1;
SUM_A:=SUM_A+values;
if(nrof_cycles> NROF_CYCLES_per_interval) then
SUM_B :=SUM_B + myinput_values[cycle];
contents_I1:=SUM_A-SUM_B;
contents_process(contents_I1);
end if;
myinput_values[cycle]:= values;
end process1;
return integer is
begin
if (all_cycles +1 > NROF_ALL_CYCLES_MAX) then
return 1;
else
return all_cycles+1;
end if;
end increment_all_cycles;
return integer is
begin
if (all_cycles –a<1) then
return (all_cycles-a + NROF_ALL_CYCLES_MAX);
else
return all_cycles-a;
end if;
end add_to_all_cycles;
return integer is
begin
all_cycles:=increment_all_cycles;
Contents_values[(all_cycles):=contents;
if (nrof_cycles>NROF_ALL_CYCLES_MAX) then
for i in 1 to 18 loop
Interval_values(i):=Contents_values(add_to_all_cycles (NROF_CYCLES*(I-1)));
end loop;
end if;
end contents_process
end preamble
Libraray IEEE;
Use IEEE.std_logic_1164.all;
Use work.preamble.all
Entity preamble_det is
Port(cycle: in std_logic;
values: in std_logic;
contents_I1: out std_logic;
Interval_values : out Input_values;
End preamble_det
Architcture behave of preamble_det is
Begin
end behave;
What line is causing the syntax error?
I already see several problems in your code.
You can't define variables in a package declaration (you should be able to define signals though). Functions can't assign values to signals or variables outside themselves, you could use procedures for that. Variables are reinitialized at each function call, you can't keep a value from one call to another. And you don't call any of the functions, so nothing will be synthesized.
I recommend instead of all those functions to put all your code in a single process. Use a cycle counter and decode your data from there.
Thanks for giving me a direction. As per your suggestion I used a Process as follows:
library ieee;
--declaring global variables
package share is
type input_values1 is array(0 to 25) of integer;
type amplitudearray1 is array(0 to 905) of integer;
type interval_values1 is array(0 to 18) of integer;
end package share;
library ieee;
use IEEE.std_logic_1164.all;
use work.share.all;
entity preamble_det is
Port(clk: in std_logic;
amplitudearray: in amplitudearray1;
interval_values: out interval_values1);
end preamble_det;
architecture behave of preamble_det is
constant nrofcycle_perinterval: integer :=25;
constant nrofinterval: integer :=18;
constant nrofallcycle_max: integer :=nrofcycle_perinterval*nrofinterval;
begin
process(clk)
variable contents_values: amplitudearray1;
variable input_values: input_values1;
variable n : integer;
variable n1 : integer;
variable nrofcycle : integer := 0;
variable cycle : integer := 0;
variable sum_a : integer := 0;
variable sum_b : integer := 0;
variable contents_I1 : integer;
variable allcycles : integer := 0;
variable i : integer;
begin
if (rising_edge(clk)) then
for n in 1 to 905 loop
if ((cycle+1) > nrofcycle_perinterval) then
cycle:= 1;
else
cycle:=cycle+1;
end if;
nrofcycle:=nrofcycle+1;
sum_a:=sum_a+(amplitudearray(n));
if (nrofcycle>nrofcycle_perinterval) then
sum_b:=sum_b+input_values(cycle);
contents_I1:=sum_a-sum_b;
if ((allcycles+1) > nrofallcycle_max) then
allcycles:= 1;
else
allcycles:= (allcycles+1);
end if;
contents_values (allcycles):=contents_I1;
if(nrofcycle>nrofallcycle_max) then
for n1 in 1 to 18 loop
if ((allcycles-(nrofcycle_perinterval*(n1-1)))<1) then
i:= (allcycles-(nrofcycle_perinterval*(n1-1))+nrofallcycle_max);
else
i:= allcycles-(nrofcycle_perinterval*(n1-1));
end if;
interval_values (n1) <= contents_values (i);
end loop;
end if;
end if;
input_values(cycle):=amplitudearray(n);
end loop;
end if;
end process;
end behave;
During running this program either Quartus II 11.0 becomes hang or I got the following errors::
Error: Out of memory in module quartus_map.exe (4097 megabytes used) while running 32-bit Quartus II on a 64-bit OS platform. Please use the 64-bit Quartus II to increase memory capacity.
Error: Current module quartus_map ended unexpectedly
Is there any way to reduce the memory? I checked the same Program in "C programming" where it works fine using 5 functions for each stage.
I read that ""Signal represents interconnection wires that connect component
instantiation ports together whereas Variable is used for local storage of temporary data and visible only inside a process"". But here I am still unable to decide which one I should take as a variable and which one as signal.
Further help will be highly appreciated.
Picking a small snippet of your code
for n in 1 to 905 loop if ((cycle+1) > nrofcycle_perinterval) then cycle:= 1; else cycle:=cycle+1; end if; nrofcycle:=nrofcycle+1; sum_a:=sum_a+(amplitudearray(n));
Do you understand what a VHDL iteration (e.g. a for loop) does? It constructs parallel logic. You have several unconstraint integer (32-bit each) arithmetic expressions inside the loop, as rough estimation the loop will consume at least several 100k logic cells. Can you imagine that Quartus doesn't like it? In any case, the design won't fit any reasonable FPGA size.
Simple conclusion, consider what you want to achieve, redesign your code to execute sequentially or find a different way to make it FPGA compatible.
Hello FvM,
I tried different way using Functions as follows::
library ieee;
--making global variables as these variables are used by 5 functions in my case
package share is
variable contents_I1: integer;
variable y: amplitudearray1;
function process1 (values: integer) return integer;
function contents_process(content:integer) return integer;
function increment_allcycle return integer;
function subfromallcycle(a: integer) return integer;
end package share;
library ieee;
use work.share.all;
end preamble_det;
function process1 (values: integer) return integer is
begin
sum_a:=sum_a+values;
end if;
input_values(cycle):=values;
end process1;
function increment_cycle return integer is
begin
return 1;
else
return cycle+1;
end if;
function contents_process(contents_I1:integer) return integer is
begin
allcycles:=increment_allcycle;
i:=subfromallcycle(nrofcycle_perinterval*(n1-1));
interval_values (n1) := contents_values (i);
end loop;
end if;
end contents_process;
function increment_allcycle return integer is
begin
return 1;
else
return (allcycles+1);
end if;
end increment_allcycle;
function subfromallcycle(a: integer) return integer is
begin
if ((allcycles-a)<1) then
return (allcycles-a+nrofallcycle_max);
else
return allcycles-a;
end if;
end subfromallcycle;
begin
process(clk)
begin
for n in 1 to 906 loop
y:= process1 (amplitudearray(n));
end loop;
end if;
end process;
end behave;
Then, I get following errors::
Error (10511): VHDL Qualified Expression error at preamble.vhd(60): contents_process type specified in Qualified Expression must match void type that is implied for expression by context
Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 1 warning
Error: Peak virtual memory: 275 megabytes
Error: Processing ended: Wed Sep 05 11:15:02 2012
Error: Elapsed time: 00:00:02
Error: Total CPU time (on all processors): 00:00:01
Could you please help me to correct it?
The syntax error is only the first of a huge number of syntax and semantic errors. I suppose they can be fixed somehow, but the new design doesn't change anything to the problem addressed in my previous post.
The first error says, you must not call a function without assigning the result to an object of correct type.
Hi, Thanks for the reply.
could you please recommend any good VHDL text book or anything else where I can understand such concepts.
your coding style still follows software programming style very much. other than just learning VHDL syntax, you got to forget about writing it similar to software coding style like C, C++, et c. honestly, you don't really need to get a good VHDL text book, just google them and you get tonnes of info.
what you might need is the book in digital logic/system design.
Hi, can anybody give some alternative way of writing array of array in VHDL having lets say 200 elements and each element consists of 14 bits .
The one I know is:
type elements is array(13 down to 0) of bit;
type array_elements is array( o to 200) of elements;
Although analysis and synthesis is succesful in Quartus
but give following errors for "Cyclone IVE" during compilation ::
Error (169281): There are 2817 IO input pads in the design, but only 281 IO input pad locations available on the device.
Error (169282): There are 2814 IO output pads in the design, but only 266 IO output pad locations available on the device.
oh, you just tied your array to I/Os...
You have to declare them as internal signals like this:
type elements is array (0 to 200) of std_logic_vector(13 downto 0);
signal bus_name : elements;
you gotta buck up your vhdl and the Quartus II basics too.
The program below compile with quartus ii for cyclone IVE.
but for confirmation: does it transfer 906 samples of 14 bit data from input to output as soon as significant bit is detected??
library ieee;
port( clk: in std_logic;
detection: out std_logic;
input: in std_logic_vector(13 downto 0);
output: out std_logic_vector(13 downto 0));
end preamble_det;
type bit_bus is array(905 downto 0) of std_logic_vector(13 downto 0);
signal element : bit_bus;
begin
transfer_data: process (clk) --transfer data at each clock
begin
if (clk'event and clk= '1') then
for i in 13 downto 8 loop
if(input(i) = '1') then
detection <= '1'; --significant bit detection
else
exit;
end if;
end loop;
for n in 905 downto 0 loop
element(n)<= input;
output<=element(n);
end loop;
end if;
end process transfer_data;
end behave;
one additional query: can we call a process using label from other process like function if we have multiple processes??
I don't think your code does what you wanted it to do.
Remember that all the lines in the "if (clk'event and clk= '1')" will be executed within the same clock cycle. So basically, at each clock cycle the 906 elements of your array are all filled with the same value: the input vector at the rising edge.
output<=element(n);This line is also executed 906 times, so the first 905 ones will be ignored and output will simply be fed with the value element(905), which is the value of input on the previous rising edge. You created a two cycle delay, and Quartus will optimize it by removing the first 905 of your array, which are useless.
detection <= '1'; --significant bit detection detection is never set to 0 anywhere in your code. It will start at an undefined value at power up (I'm not sure Quartus will set it to 0, but it doesn't need to do this to be compliant with the VHDL specification) and once set to 1 it will never change back. If Quartus is smart enough it may decide to optimize you code by just setting detection at a fixed value of 1 (but I haven't tested this).
--- Quote Start ---
--- Quote End ---
you can't "call" a process, a process is a piece of hardware that is always there. You can use functions and procedures, but even there when you use them it isn't a "call" as you understand it in software, it is an instantiation. Each "call" will generate a new piece of hardware.
As other replies suggested, you should start with a book about logic design and VHDL. Some people gave some good references on this forum, a search will probably help.
