17249 Discussions
Determining the Max payload size encoding
pdewanga
Hi Quartus Support Team,
Attaching the screen-shot from the "L- and H-tile Avalon® Streaming and Single Root I/O Virtualization (SRIOV) Intel® FPGA IP for PCI Express* User Guide" Table 43.
What is the encoded value of [2:0] Max payload size ?
is it something as follows -
000 -128Byte
001- 256Byte
010- 12Bytes
011-1024Byte
------ or different ?
Also what is the encoded value in [5:3] Max rd req size  ??
Please share more details about the encoded value of this 2 signals
Wincent_Altera
Thanks for correcting me, my apologize for misunderstanding the question.
For your information the spec is not owned by intel, it is a general spec that all PCIe IP need to follow.
You can get the detail in "PCI Express® Base Specification" in the web.
For your question, I do help to printscreen it to you.
Max rd req size
Max payload size
Hope this answer your question, Let me know if this is helpful to you.
Wincent_Intel
Wincent_Altera
Thank you for reaching out.
Just to let you know that Intel has received your support request and I am assigned to work on it.
Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Wei Chuan
Wincent_Altera
From low level description, it is part of the Transaction Layer (TL) bus provides a subset of the information stored in the Configuration Space. Those Information on the Transaction Layer (TL) bus is time-division multiplexed (TDM). When tl_cfg_func[1:0]= 2'b00tl_cfg_ctl[31:0] drives PF0 Configuration Space register values for eight consecutive cycles. The next 40 cycles are reserved. Then, the 48-cycle pattern repeats as per mention in the user guide.
Can I know is there any specific reason asking that question ? do you facing problem on the configuration ?
Wincent_Intel
pdewanga
The text you copy and pasted is from user guide, that we have gone through.
There is no issue of configuration. I just want to use this two following signal for our design.
Actual question to make you more clear-
question:- Please share more details about the encoded value of this signals  ( [5:3] Max rd req size [2:0] Max payload size ). What does each state means ?
Please don't copy paste the user guide content, We have gone through that but nothing is listed there properly.
Wincent_Altera
Max rd req size
Max payload size
Wincent_Intel
pdewanga
Hi wchiah,
Thanks for providing answer.
Piyush
Wincent_Altera
Hi Piyush,
Thanks for your reply, With that said I will close this case on my place.
The community users will be able to help you with your follow-up questions.
If you have new problem, feel free to open another community thread.
If you feel your support experience was less than a 9 or 10,
please allow me to correct it before closing or please let me know the cause so that I may improve your future support experience.
Wincent_Intel
Wincent_Altera
I wish to follow up with you about this case.
I believe my previous reply answered your question, Do you have any further questions on this matter ?
​​​​​​​Else I would like to have your permission to close this forum ticket
Wincent_Intel
