17252 Discusiones
Difference between area.rpt and "kernelname".area
Colaborador Distinguido II
1.496 Vistas
Hello, I have compiled an example kernel and I found the files
- area.rpt
- "kernelname".area
in the bin folder.
Does the file area.rpt shows the total amount of Hardware used (for the Kernel + BSP)?
And the file vecadd.area shows the Hardwareelements used only for this function?
In this files there is also a section called Util, can someone tell me what this stands for? (I can´t find a translation to german where this word makes sense in this context)
Exampleoutput:
LEs: 3.09659 %
FFs: 1.89328 %
RAMs: 7.7821 %
DSPs: 0 %
util: 4.68994 %
0 kudos
3 Respuestas
743 Vistas
Can you attach the files to your reply? These reports have been renamed/removed/changed numerous times in different versions of AOC and these files that you mention do not exist in kernels compiled with v16.x and above.
743 Vistas
I attached the files, compiled them with V.14.x
743 Vistas
I could be wrong (the version you are using is too old) but as you yourself said, the area.rpt is probably kernel + BSP while "kernel_name".area is kernel only. The "Util" field most likely shows your logic (ALM) utilization, i.e. the number of logic elements with at least one ALUT or register occupied in it.
Responder
