17267 Discussions
Difference between area.rpt and "kernelname".area
Hello, I have compiled an example kernel and I found the files
- area.rpt
- "kernelname".area
in the bin folder.
Does the file area.rpt shows the total amount of Hardware used (for the Kernel + BSP)?
And the file vecadd.area shows the Hardwareelements used only for this function?
In this files there is also a section called Util, can someone tell me what this stands for? (I can´t find a translation to german where this word makes sense in this context)
Exampleoutput:
LEs: 3.09659 %
FFs: 1.89328 %
RAMs: 7.7821 %
DSPs: 0 %
util: 4.68994 %
Can you attach the files to your reply? These reports have been renamed/removed/changed numerous times in different versions of AOC and these files that you mention do not exist in kernels compiled with v16.x and above.
I attached the files, compiled them with V.14.x
I could be wrong (the version you are using is too old) but as you yourself said, the area.rpt is probably kernel + BSP while "kernel_name".area is kernel only. The "Util" field most likely shows your logic (ALM) utilization, i.e. the number of logic elements with at least one ALUT or register occupied in it.
