17257 Discussions
Difference of 2 process?
I have a VHDL code for process as below:
process (vin_clk) begin if rising_edge(vin_clk) then if (rst_n = '0') then data_cnt <= "000000000000"; elsif (frame_flag_vin = '1') then data_cnt <= "000000000000"; elsif (vin_de = '1') then if (data_cnt = vin_width - "000000000001") then data_cnt <= "000000000000"; else data_cnt <= data_cnt + "000000000001"; end if; else data_cnt <= data_cnt; end if; end if; end process;
My question is: if to delete the last "else" branch (data_cnt <= data_cnt;), what will the difference be? or no difference?
It's the same. See the RTL view.
No difference, because all signals hold their value in VHDL anyway.
If you did it without a clock, it would also make no difference, as either way (with or without the else) you would be inferring a latch.
It is usual to leave out anything that occurs implicitly (like the final else branches).
What you're asking in the code is for the synthesisor to connect the en port of the inferred register to everything in the if branches.
