I have a VHDL code for process as below:
process (vin_clk) begin
if rising_edge(vin_clk) then
if (rst_n = '0') then
data_cnt <= "000000000000";
elsif (frame_flag_vin = '1') then
elsif (vin_de = '1') then
if (data_cnt = vin_width - "000000000001") then
else
data_cnt <= data_cnt + "000000000001";
end if;
else
data_cnt <= data_cnt;
end if;
end if;
end process;
My question is: if to delete the last "else" branch (data_cnt <= data_cnt;), what will the difference be? or no difference?
It's the same. See the RTL view.
No difference, because all signals hold their value in VHDL anyway.
If you did it without a clock, it would also make no difference, as either way (with or without the else) you would be inferring a latch. It is usual to leave out anything that occurs implicitly (like the final else branches). What you're asking in the code is for the synthesisor to connect the en port of the inferred register to everything in the if branches.
