Divided integer number
Can I divide the integer number (for example, 120) to each of the numbers 1 2 0 in different variables?
What exactly is the context? What are you trying to do?
You could extract 1 2 0 out in VHDL - but why?
From the AD converter to read 8-bit vector and the need to get him on the numbers in an integer. I need to send individual characters to UART
--- Quote Start ---
--- Quote End ---
Problem solved. This is example.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity test is
port( INput:in integer range 0 to 999:=123);
end test;
architecture main of test is
signal hundred:integer range 0 to 9;
signal ten :integer range 0 to 9 ;
signal unit : integer range 0 to 9;
begin
hundred<=INput/100; --1
ten<=((INput rem 100)/(10)); --2
unit<=(INput rem 10) ; --3
end main;
Hello please.
I need to show 12 -bit value (integer) of the AD converter to the 4 - digit display.
This is my functional code, but takes 756 total logic elements (many).
I need a way to effectively divide the number and use the minimum number of logic elements.
library ieee;
entity Number_converter is
port( INPUT12bit: in unsigned (11 downto 0);
digit1: out unsigned (11 downto 0);
digit2: out unsigned (11 downto 0);
digit3: out unsigned (11 downto 0);
digit4: out unsigned (11 downto 0));
end entity;
architecture main of Number_converter is
signal INPUT12bit_INT:integer range 0 to 4096;
attribute ramstyle: string;
attribute ramstyle of digit4 : signal is "M9K";
begin
digit1<=(INPUT12bit rem 10)/1;
digit2<=(INPUT12bit rem 100)/10;
digit3<=(INPUT12bit rem 1000)/100;
digit4<=(INPUT12bit/1000);
end main;
I can't read VHDL, sorry. But if you want to trade logic elements for hard memory blocks you could use a look-up table. It would need to be 2^12 deep (4096) and wide enough to drive your 4-digit display. I would think this would take 4 bits per digit, but you've got your output digits defined as 12 bits each. Assuming you only need 16 bits out (4 bits per digit) the look-up table would consume 8 M9Ks I believe. They're there so you may as well use them.
Why don't you simply use the standard function to_string() ?
This way, each number can be addressed by indexes representing each descending decimal order.
--- Quote Start ---
--- Quote End ---
Because to_string is not synthesisable.
To the op.. Why not just have it in hex? That way you just need a small lut for each hex digit.
If you don't need it fast, you can use a double dabble algorithm, which cqn help you convert binary to the base of your choice, even bcd.
--- Quote Start ---
--- Quote End ---
Please, How to?
use your favorite web search engine an enter double dabble as keywords, you'll find plenty of resources there.
--- Quote Start ---
--- Quote End ---
Problem solved. This is my code. 133 logic elements
library ieee;
entity converter is
port( INPUT12bit: in unsigned (11 downto 0):="000000101010";
digit1_out: buffer integer range 0 to 10;
digit2_out: buffer integer range 0 to 10;
digit3_out: buffer integer range 0 to 10;
digit4_out: buffer integer range 0 to 10;
clk :in std_logic);
end entity;
architecture main of converter is
begin
process(clk)
variable digit1: integer range 0 to 10;
variable digit2: integer range 0 to 10;
variable digit3: integer range 0 to 10;
variable digit4: integer range 0 to 10;
VARIABLE decount_INPUT12bit :unsigned (11 downto 0);
variable default_INPUT12bit :unsigned (11 downto 0);
variable LAST_INPUT12bit :unsigned (11 downto 0);
variable LAST1_INPUT12bit :unsigned (11 downto 0);
variable ENABLE: std_logic:='0';
begin
if rising_edge(clk) then
if ENABLE='1' then
decount_INPUT12bit := decount_INPUT12bit - 1;
digit1:=digit1 + 1;
if digit1=10 then
digit1:=0;
digit2:=digit2 + 1;
if digit2=10 then
digit2:=0;
digit3:=digit3 + 1;
if digit3=10 then
digit3:=0;
digit4:=digit4 + 1;
end if;
end if;
end if;
end if;
if LAST_INPUT12bit/=INPUT12bit then
ENABLE:='1';
if INPUT12bit/=LAST1_INPUT12bit then
decount_INPUT12bit:=INPUT12bit;
default_INPUT12bit:=INPUT12bit;
LAST1_INPUT12bit:=INPUT12bit;
digit1:=0;
digit2:=0;
digit3:=0;
digit4:=0;
end if;
end if;
if decount_INPUT12bit = "000000000000" then
LAST_INPUT12bit:=default_INPUT12bit;
ENABLE:='0';
digit1_out<=digit1;
digit2_out<=digit2;
digit3_out<=digit3;
digit4_out<=digit4;
end if;
end if;
end process;
end main;
This might have a small logic footprint, but I can see the performance being rather poor, due to the large cascaded logic chains because of no pipelining.
--- Quote Start ---
--- Quote End ---
Yes I need little logic elements. Slow transfer no harm. This module will be multiplexed for 8 digits - 4digit and 4 digit
Could you use code tags when posting code in the future?
This makes it way esier to read.
