17257 Discussions
Using: set_global_assignment -name QIP_FILE in .tcl script fails
Title says it all really.
I have a setup that requires the use of environment variables when setting these kind of assignments. Most seem to work, but when it comes to QIP_FILE assignments in a tcl script, Quartus errors.
Using an explicit path in the .qsf project file works. Is there any way of using environment variables in a .qsf file, or am I doing something wrong in my .tcl script?
The line I am using is:
set_global_assignment -name QIP_FILE $::env(MY_VAR_PATH)/my/path/my.qip
Any help on this would be great,
Thanks in advance!
You shouldn't need the full path to your qip file. The command line tools use the connected directory as the starting point. If you run your script while connected to your top level project directory it should work fine.
