Duty cycle VHDL
Hello!
I'm trying to create an A and B pulse and change the duty cycle of that pulse. The program shown below just changes the frequency and creates an A and B pulse, but I'm not able to change the duty cycle.
Has anyone a tip or idea??
library ieee;
use ieee.std_logic_1164.all;
entity freq is
port(
clk :in std_logic;
rst :in std_logic;
S0 :in std_logic;
out_0 :out std_logic;
out_1 :out std_logic
end freq;
architecture Behavioral of freq is
signal cnt : integer;
signal temp : std_logic;
signal temp_out : std_logic;
begin
--XXXXXXXXXXXXXXXXXXXXXXXXXXXX
--CLOCK
process(clk)
begin
if(rst='1') then
temp <= '0';
cnt <= 0;
elsif(clk'event and clk='1') then
if(cnt= 1000000) then
temp <= not temp;
cnt <= 0;
else
cnt <= cnt +1 ;
end if;
end if;
--Switch
if (S0='1') then
temp_out <= temp;
else
temp_out <= '0';
end if;
end process;
out_0 <= temp_out;
out_1 <= not temp_out;
end Behavioral;
Hi Frans
Infact your code simply creates a 50/50 square wave.
I think this is what you need:
library altera; library IEEE; use IEEE.std_logic_1164.all; use IEEE.numeric_std.all; -- for the unsigned type entity pwm_generator is port (CLKIN : in std_logic; TPERIOD : in unsigned(7 downto 0); TWIDTH : in unsigned(7 downto 0); PWM : out std_logic ); end entity pwm_generator; architecture pwm_gen_a of pwm_generator is subtype small_int is natural range 0 to 500; begin update: process(CLKIN) is variable tcnt : small_int := 0; begin if rising_edge(CLKIN) then tcnt := tcnt + 1; if tcnt = TPERIOD then tcnt := 0; end if; if tcnt >= TWIDTH then PWM <= '0'; else PWM <= '1'; end if; end if; end process; end architecture pwm_gen_a;
You may need to change TPERIOD and TWIDTH bit length to meet your specs.
You must also add the pwm switching function.
