ECO problems
I have a project compiled with imcremental compilation, I have several partition with post fit preservation and the top level which included some block not included in separate partitions whose preservation is source file. I used some signalprobe to check some points in the circuits. Now i need to recompile because I made a code modification in a block on the top level and every time I see the warning that to mantain the ECO changes all partiton were fixed at post fit, but in this way I cannot made any modification to the source code....
How is possible to discard eco chages, I deleted all the signalprobe, but there is still that warning.
How is possible to recompile?
