I have not done any functional simulation for some time, but the last time I did, using Quartus 8.x and Modelsim-Altera (6.1g?) there was a mechanism to automatically generate a test bench skeleton, which I found very convenient.
Using QII v 9.1 SP2 and Modelsim-Altera 6.5, I have not been able to figure out how to do this. Is this a feature which has disappeared? Thanks for any help MichealLink Copied
I managed to find it -- it comes up under Processing -> Start -> Start test Bench Template Writer
As an aside, you can do this using Emacs too.
Very interesting. Emacs is my standard editor, but I have not been able to find an option in the menus to generate the template from within emacs. If you can provide further info it will be appreciated.
