17252 Discussions
EPM7128SLC84-15 - Quartus 2 13.0.1 SP1 Web - Programming Probem - no JTAG ID
Hello Altera-Profis,
I want to program a EPM7128SLC84-15 in a university project. I have already programmed it on a computer in the university.
Now I want to work with the Board on my own Computer.
But every time I want to load the Project on the chip I get following Message:
Error (209001): JTAG ID code specified in JEDEC STAPL Format File does not match any valid JTAG ID codes for device
I use following Quartus Version:
13.0.1 Build 232 06/12/2013 SP 1 SJ Web Edition
I can not match the right CPLD in the Programmer, so I think i need some JTAG ID codes for my CPLD or?
In the Programmer is the Device: EPM7128SL84.
So it is the wrong device which is deteced.
I hope you can help me.
best greets Lennart
No one can help me?
Have you installed the programming file?
What is the prgramming file exactly ?
I have found in the Compilation Repot in the Assembler Setting following Option:
"Generate a JEDEC STAPL Format File (.jam) for Target Device | Off"
Is that the wrong Setting? How can I change it?
Thank you for replying.
I meant the Quartus II file that tells it how to program the device.
Hm.. is this the .pof file?
In the Programmer, the .pof file is listed and there I checked "Program/Configure"
Are there more files to "install" ?
No. It's part of the installation.
Oh..yes I have installed all Device Familys during installation. But I am not sure because in the programmer I have no option for "EPM7128SLC84" but "EPM7128SL84". Although it works in university with the option " EPM7128SL84" too.
