I am trying to run a VWF and I get this error:
**** Running the ModelSim simulation ****
c:/intelfpga_lite/19.1/modelsim_ae/win32aloem//vsim -c -do lab1_ex.do
Unable to checkout a license. Vsim is closing.
** Fatal: Invalid license environment. Application closing.
Unable to checkout a license. Make sure your license file environment variables are set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Modelsim - Intel FPGA Edition uses the following environment variables to check the licenses (listed in the order of preference)
1. MGLS_LICENSE_FILE
2. LM_LICENSE_FILE.
Error.
I can't find anything with the newer versions of quartus. I have Modelsim Starter Edition 19.1 downloaded along with quartus lite.
連結已複製
Can you check if you are installing the Starter edition? The path indicates that you are using the paid edition of the software -- modelsim_ae. The starter edition is modelsim_ase.
KhaiY
Hola,
tengo el mismo problema pero en majaro linux, el mensaje que arroja es este:
Unable to find the license file. It appears that your license file environment variable (e.g., LM_LICENSE_FILE) is not
set correctly.
** Error: Invalid license environment. Application closing.
We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
KhaiY
2. LM_LICENSE_FILE.
i also have same error
do u have a solution for this?
my error code is
c:/altera/13.1/modelsim_ase/win32aloem//vsim -c -do Experiment1.do
Modelsim-Altera uses the following environment variables to check the licenses (listed in the order of preference)
2. LM_LICENSE_FILE.
Error.
Hello!
I got the solution for this problem. I created a small video that explains how to obtain a free licence from Intel and how to set environment variable to get Questa running. See more on my YT channel : Watch on YouTube - How to fix Unable to checkout a licence.
Cheers
my error code is
2. LM_LICENSE_FILE.
Error.
