17257 Discussions
ERROR: packager check failed with output '' (Intel FPGA)
PVeli
when we are compiling  OpenCL kernel for PAC cards in Intel Dev Cloud, I am receiving the above error. The log file is attached.
Labels (2)
AnilErinch_A_Intel
Hi ,
Please check if you are still getting this issue in Dev cloud , can you let us know what the variable value ADAPT_PACKAGER_BIN looks like in the environment.
You can refer the below link for checking this variable.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/embedded/2019/error--packager-tool-failed-to-run.html
Thanks and Regards
Anil
