I've used the following line of code in Xilinx with no issue, but now Quartus is flagging this as an error. The error is shown below.
--error Error (10779): VHDL error at addr.vhd(609): expression is not constant --code... sum_azp_azpos_scale <= EXT( sum_azp_azpos_comp(15 downto (CONV_INTEGER(az_scale_fact1))), 16); I'm using the following packages. --packages library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; use IEEE.STD_LOGIC_MISC.ALL; use IEEE.NUMERIC_BIT.ALL; Any suggestions?Link Copied
yes, altera doesnt like non constant ranges. You'll have to use a select to slice the signal sum_azp_azpos_comp, and then extend it with the EXT function.
Thanks!
Could you please give me a quick example? The az_scale_fact1 is defined below. --code signal az_scale_fact1: std_logic_vector(2 downto 0);- Mark as New
assuming this is outside a process:
with az_scale_fact1 select
sum_azp_azpos_scale <= sum_azp_azpos_comp(15 downto 0) when "000",
EXT( sum_azp_azpos_comp(15 downto 1) , 16) when "001",
EXT( sum_azp_azpos_comp(15 downto 2) , 16) when "010",
--etc
can I ask why az_scale_fact1 is a std_logic_vector and not an integer? and also - Im going to be a code facist - any chance you want to come into the 1990's and use IEEE standard VHDL?
