17267 Discussions
Eclipse not starting in Linux version
I have done quite a bit of searching and I have not found a solution. When trying to open Eclipse Mars in Linux version 17.1, I get a segmentation fault error. Using valgrind, I find a strcat copy error that leads to segmentation fault. The problem seems to be an issue with libboost 1.59??
Is there a patch or workaround for this?
element4lifex8
I was also experiencing this same error when trying to run the eclipse-nios2 executable on Ubuntu 17.10 with both Quartus 17.1 and 18.0.0. Turns out I combined a solution from this this old Altera support forum post
https://forums.intel.com/s/question/0D50P00003yyOP3SAM/niosiiide-not-working-in-120-linux
and this Xilinx forum post
https://forums.xilinx.com/t5/Embedded-Development-Tools/Vivado-2016-3-SDK-launches-with-a-segmentation-fault/m-p/729055#M40368
The solution consisted of downloading some 32bit gtk libraries mentioned in the Altera forum post, and setting the SWT_GTK3 env var equal to 0. After both of these steps I could open the eclipse-nios2 executable just fine.
