17253 Discussions
Encounter problems when I using Avalon MM templates for read
Hi
I refer to Avalon MM templates to achieve master read, but I only read the first 64 document (s)
As long as I read the document beyond the data output 64 is the last document 64
For example :
I want to output from 0 to 127, but the results will only be 66 to 127
This is because I have not set some signal right ? or my code have something wrong?
thx for all
please help me, I'm going crazy for begug!
//*******************************************************************************// // // // //******************************************************************************* `timescale 1ns/1ns module master ( clk, reset, // DDR2 master port master_address, master_byteenable, master_waitrequest, go, /////////////////write/////////////////////// master_write, master_writedata, source_data, write_addr, write_en, /////////////////////////////////////////////////////////////////// master_readdata, master_readdatavalid, to_addr_readdata, read_en, read_addr, master_read, index, // for_read_en fifo_ren, fifo_wen, fifo_clk, for_fifo, addr_ck ); input clk; input reset; input index; input addr_ck; output fifo_wen; output reg fifo_ren; output fifo_clk; // DDR2 master port input for_fifo; output reg master_address; output master_byteenable; input master_waitrequest; output go; input write_en; /////////////////write/////////////////////// output master_write; output master_writedata,to_addr_readdata; input source_data; input write_addr; /////////////////////////////////////////////////////////////////// input master_readdata; input master_readdatavalid; output reg master_read; input read_en; input read_addr; ////////////////////////////////////////////////////////// reg to_addr_readdata; wire read_go,write_go; assign master_byteenable = 4'b1111; assign master_writedata = source_data; assign go = master_waitrequest; assign fifo_clk_1 = ( clk & (!master_waitrequest) & for_fifo); assign fifo_clk = (fifo_clk_1 & master_read); assign fifo_wen = (read_en && (!master_waitrequest)); always @(posedge clk or negedge reset) begin if (!reset) begin to_addr_readdata <=# 1 0; master_address <=# 1 0; master_read <=# 1 0; end else if (addr_ck == 1) begin to_addr_readdata <=# 1 master_readdata; master_address <=# 1 read_addr; master_read <=# 1 read_en; end end endmodule
