17252 Discussions
Error (10028): Can't resolve multiple constant drivers for net "P[6]"
below are my code.
when I compile, Error (10028): Can't resolve multiple constant drivers... is coming out, anyone knows what's the problem?
entity DU is
port ( clk, reset, ctrlA, ldA : in std_logic;
ctrlB, ldB, Psel, ldP : in std_logic;
dataA, dataB: in std_logic_vector (3 downto 0);
z, b0 : out std_logic;
P : buffer std_logic_vector (7 downto 0));
end DU;
architecture Structural of DU is
signal Ain, Sum, dataP :std_logic_vector(7 downto 0);
signal A :std_logic_vector(7 downto 0);
signal B :std_logic_vector(3 downto 0);
component reg8 port
(ldP, clk, reset: in std_logic;
data: in std_logic_vector(7 downto 0);
Q : buffer std_logic_vector(7 downto 0));
end component;
component shiftLreg8 port
(d : in std_logic_vector (7 downto 0);
w,clk,reset,ctrlA,ldA: in std_logic;
Q : buffer std_logic_vector (7 downto 0));
end component;
component shiftRreg4 port
(d : in std_logic_vector (3 downto 0);
w, clk, reset, ctrlB, ldB: in std_logic;
Q : buffer std_logic_vector (3 downto 0);
b0 : out std_logic);
end component;
begin
c1: reg8 port map (ldP, clk, reset, dataP, P);
c2: shiftLreg8 port map (Ain,'0',clk,reset,ctrlA,ldA,A);
c3: shiftRreg4 port map (dataB,'0',clk,reset,ctrlB,ldB,B,b0);
Ain <="0000"&dataA;
process (clk,reset)begin
if reset='1' then
A <=(others=>'0');
B <=(others=>'0');
P <=(others=>'0');
elsif (clk'event and clk ='1') then
A <= Ain;
B <= dataB;
P <= dataP;
end if;
end process;
process (Psel) begin
if Psel='1' then dataP <= A+P;
else dataP <= (others=>'0');
end if;
end process;
process (B) begin
if B = "0000" then z <= '1';
else z <= '0';
end if;
end process;
end Structural;
Besides P also A and B multiple drivers. They are driven in two places, in the first process and in one of the component instances c1-c3. This is like shorting to logic outputs, it's not allowed by VHDL syntax rules. You have to decide, which side is intended to drive the respective nets.
thanks for info. the code can work now.
thanks a lot. :)
