17259 Discussions
How to use the $setup() system function in the testbench?
I want to use the $setup() and $hold() system function to check the setup time and hold time in the Verilog testbench,but there is a note show that " unexpected "$setup"" in the Modelsim.
could you help me?
thank you!
ha ha!I have found the usage of the $setup().
`timescale 1 ns/ 1 ps module diff_notifier(clk,data_A,data_B,data_out,reset); input clk; input reset; input data_A; input data_B; output data_out; specify $setup(data_A,posedge clk,1); $hold(posedge clk,data_A,0.1); endspecify endmodule module LED_vlg_tst(); reg eachvec; // test vector input registers reg clk; reg data_A; reg data_B; reg reset; reg pha,phb; // wires wire data_out; wire notifier; integer TF; integer i; // assign statements (if any) LED i1 ( // port map - connection between master ports and signals/registers .clk(clk), .data_A(data_A), .data_B(data_B), .data_out(data_out), .reset(reset) ); diff_notifier U1(clk,data_A,data_B,data_out,reset); initial begin clk=0; TF=$fopen("DATABASE.txt"); $readmemb("WY.txt",pha); $readmemb("KL.txt",phb); for(i=0;i<8;i=i+1) begin # 5; data_A=pha; data_B=phb; # 10; $fdisplay(TF,"%b",data_out); # 5; end $fclose(TF); $display("Running testbench"); end always# 10 clk=~clk; endmodule
